2011 Tundra Tire Pressure Sensors
Discussion in 'Wheels & Tires' started by Dutchman#77, Oct 8, 2019.
  1. Oct 8, 2019 at 8:37 AM
    Dutchman#77
    Dutchman#77 [OP] New Member
    2011 Black Tundra
    None
    Looks like one of mine bit the dust. Warning pops up when starting the truck, blinks for several minutes, then remains on. What is the cost to replace these things. The pressure is good on all, including the spare. Thanks
  2. Oct 8, 2019 at 9:36 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    At Discount Tire/ Americas Tire we charge $60+tax per sensor with free programming afterwards.
    The sensors carry a 6 year 72K mile warranty.
    TheBeast likes this.
  3. Oct 8, 2019 at 10:13 AM
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    Mine did something similar and just needed to be reprogrammed. Not the expert by any means but was told each sensor has an RF-ID so your truck only reads the sensors that are programmed or taught. One of mine couldn't be read because the computer lost the RF-ID somehow, took 5 minutes to reprogram and it was free.
    BTW the dealer told me I had a bad sensor and wanted ~ $100...so I took it back to the shop that I had recently purchased the rims and tires from and they said they hear the same story all the time.
  4. Oct 8, 2019 at 10:15 AM
    Dutchman#77
    2011 Black Tundra
    None
  5. Oct 8, 2019 at 10:17 AM
    Dutchman#77
    2011 Black Tundra
    None
    Thanks - I presume this the going rate...….
  6. Oct 8, 2019 at 10:17 AM
    HbbTundra08
    HbbTundra08 Epstein Didn't Kill Himself
    Brad
    2008 Toyota Tundra Crewmax SR5 2wd 5.7L
    TAC Stainless Steel Bull Bar RCI Steel Engine Skid Plate Two Stainless Steel 100w KC Daylighters Black Husky Weatherbeater Floor Liners front and rear. Kenwood Media System with Rear License plate backup camera integrated.
    Hoping its just a tpms wheel sensor replacement and not a tpms receiver replacement!!
    My 08 Tundra is at 216000 miles, TPMS sensor did same thing. Had all 4 sensors changed at Discount Tire and light would not reset, took it back twice in case it was their mistake.
    Ended up taking it to the dealer and they scanned it all and told me the TPMS receiver was worn out. Basically it communicated with your tpms receivers in the wheels and tells your vehicle if it should blink a tire light.
  7. Oct 9, 2019 at 6:27 AM
    Dutchman#77
    2011 Black Tundra
    None
    Eeeeeeeeek that could not have been cheap.
    HbbTundra08[QUOTED] likes this.
  8. Oct 9, 2019 at 9:30 AM
    HbbTundra08
    Brad
    9.9/10 times its just gonna be a TPMS wheel sensor from what ive seen. My truck is a daily driver so makes sense that reciever went out after 11 years or so lol.
    Dealer wanted to charge some $600+ for the sensor...just a sensor. Then add on 2 hours of labor to get to an $800+ cost.
    Its easy to swap out inside the glove box, I plan to just go find one online or maybe a used one from like a 2014 Tundra that got wrecked or something.
    At the moment I just drive it with the solid TPMS light on lol
    I rotate the tires regularly and check the pressures...if a tire is flat I'll see it, and if one blows out I'll know it!:rofl:Way cheaper in the short run, it ain't hurting nothing!
  9. Oct 9, 2019 at 3:11 PM
    Dutchman#77
    2011 Black Tundra
    None
    I like your thinking. LOL
  10. Oct 9, 2019 at 3:12 PM
    Dutchman#77
    2011 Black Tundra
    None
    I like your thinking and I shall do the same......
    Black Wolf likes this.
  11. Oct 9, 2019 at 3:26 PM
    My 07 came with Nitto tires and no TPM sensors and a blinking warning light. BFD. When I put on a set a new Coopers.....no sensors. BFD. I check my tire psi myself. Old fart thing. Cheaper too. I survived this long without sensors. More worried about ice melting too fast in my C K Polar Pop...
    HbbTundra08 likes this.
