2011 Tundra, Horn not Working
Discussion in '2nd Gen Tundras (2007-2013)' started by Stelios, Dec 9, 2017.
  1. Oct 8, 2019 at 7:11 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    Just purchased a 2011 and found out the horn dosent work. Anyone have a Toyota P/N for the clockspring? thanks
  2. Aug 2, 2020 at 7:29 PM
    justinx987
    justinx987 New Member
    Justin
    2001 v8 tundra 2wd access
    hey guys, same problem here. I have recently bought 2011 DC 4x4. No horn, radio controls, blue tooth, or cruise. any current links, how to's, videos, or advise would be much appreciated...
  3. Aug 3, 2020 at 11:44 AM
    TalleyHo
    TalleyHo New Member
    2011 Tundra SR5
    My daughter just accused me of messing up her horn when I was looking at her truck the other day.
    https://www.toyotapartsdeal.com/oem...ation=electrical/switch_relay_computer,,84307
    The above link is dead, but it appears the part number is 843060E010
    Time to go scavenging for a replacement.
    For those that triggered the air bag -- do you know why that happened? I have the same irrational fear now! I need to get on this PDQ b/c her inspection/registration expires this month. Alternate is a button on the dash -- tho someone mentioned they installed a floor button for the horn - that's kind of neat. Like an old school high beam.
  4. Sep 21, 2020 at 9:40 AM
    BrianGJR
    BrianGJR New Member
    2012 Tundra Platinum
    Just completed my clockspring replacement. Followed all the warnings about disconnecting the battery and key out of the ignition....Heed the 34 Ft lbs torque on the steering nut though. Snapped mine off and had to tap the hole with a 5/16 tap and used a grade 8 bolt. Not going to lie I freaked out a little when that ratchet spun and that nut came flying off!! Once everything was back together it all works fine. No lights or anything.
  5. Sep 21, 2020 at 9:50 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Wow...First time I ever heard of that happening!
  6. Sep 22, 2020 at 1:25 PM
    BrianGJR
    BrianGJR New Member
    CTB Mike figured I needed the the puller to take it off that it would need to be pressed back on. Ha! NOPE!
  7. Sep 22, 2020 at 1:42 PM
    CTB Mike
    Southern Arizona
    I didn't need a puller either when I did mine.
