2011 Rear window problem
Discussion in 'General Tundra Discussion' started by BJones, Feb 1, 2015.
  1. Feb 1, 2015 at 11:03 AM
    BJones
    BJones [OP] New Member
    Bill
    My rear sliding window is stuck in the open position. Any suggestions? Thanks
  2. Feb 1, 2015 at 12:19 PM
    Mike Tread lightly.
    south carolina
    Is it power? If it is check the fuses?
  3. Feb 1, 2015 at 12:37 PM
    BJones
    Bill
    Yes it is power. You can hear the motor going back and fourth but the window doesn't move.
  4. Feb 1, 2015 at 3:22 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I'm guessing motor or rack. Might want to pull of the back plastic and check it out.
  5. Feb 1, 2015 at 4:35 PM
    Im going to go with the motor...or perhaps a bad relay since you can hear it trying to close?
  6. Feb 25, 2015 at 10:25 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Check the cable, that runs in the track, behind the headrest.
  7. Feb 26, 2015 at 2:38 PM
    Mike Tread lightly.
    south carolina
    If the motor is running, then the assembly that runs it is bad or damaged..
    JROCK915 likes this.
  8. Mar 18, 2015 at 9:33 PM
    csuviper
    Broomfield, CO
