2011 air suspension
Discussion in 'Suspension' started by Jjones35117, Apr 14, 2019.
  1. Apr 14, 2019 at 1:04 PM
    Jjones35117
    Jjones35117 [OP] New Member
    Jake
    2011 tundra
    Hello everyone I'm a new tundra owner. I bought a 2011 tundra with about 107k miles on it. The guy I bought it from claimed it had air suspension on it installed from the factory. He stated that if I hooked up a trailer and the back sagged to a certain point a compressor would kick on and raise the back of the truck back up level.
    I have been under the truck and it does have the airbags and compressor but I've never seen it come on and I have hauled some major loads where the back sagged bad.
    So my question is where do I need to start to try to get this feature working?
    I have checked fuse boxes but cant seem to find a fuse description that would seem to match what I'm looking for.
  2. Apr 14, 2019 at 1:08 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    It is definately aftermarket, not a factory option. I would look for a switch installed somewhere on dash or trace the wires from point a to b.
  3. Apr 14, 2019 at 1:18 PM
    Jjones35117
    Jake
    2011 tundra
    Ok I have a wire jammed up under a relay under the hood with a 15 amp fuse in it. The fuse is good but I may have a bad connection somewhere. Thanks for the help
  4. Apr 14, 2019 at 1:19 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Welcome from NE PA
    Jjones35117[OP] likes this.
  5. Apr 14, 2019 at 1:26 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    If the system is weight sensing you should have some type of height sensor or height sensing switch to actuate the solenoid. Do you see some type of sensor attached to the rear frame with a linkage to the axle? I would also start by looking under under the truck and trace the airlines from the air springs, they should lead to a solenoid. Then trace the wiring from the solenoid. Hopefully this will help you figure out is the system is laid out. The relay should have a control side and output side. If you have a voltmeter you may need to do a little electrical diag.
    joonbug likes this.
  6. Apr 14, 2019 at 1:26 PM
    Porschetech29
    Francis
    Oh ya, definitely not factory
    joonbug likes this.
  7. Apr 14, 2019 at 1:33 PM
    Jjones35117
    Jake
    2011 tundra
    I have a multimeter and trouble shooting it that way should be no problem at all. I really wanted to know if it was factory or aftermarket so I knew kinda what I was getting into.
  8. Apr 14, 2019 at 2:49 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    If there are no airbags on your rear axle then someone removed it. Or he lied.
  9. Apr 14, 2019 at 3:52 PM
    Jjones35117
    Jake
    2011 tundra
    There are airbags there and the compressor is there. I've just never seen it work
  10. Apr 15, 2019 at 3:19 PM
    Jjones35117
    Jake
    2011 tundra
    Ok so I got an update and a few more questions. First of all I tracked the wire back to the fuse box under the hood and it was pulling power from a leg of a relay marked “back p/w no.1” what is that relay controlling and when would it come on?
    Secondly the wiring under the truck goes to a compressor and some sore of control box I’m thinking a regulator maybe. Anyway the only writing I can find on any of it say “made by mix” and the witing on the wires says wireless harness.
    Any help would be appreciated
  11. Apr 15, 2019 at 3:20 PM
    Jjones35117
    Jake
    2011 tundra
    Also I could not find a limit switch that would turn it on or off any ideas where to look? I looked all around the shocks and leaf springs
  12. Apr 15, 2019 at 3:42 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Got any pictures ?
  13. Apr 15, 2019 at 3:43 PM
    Jjones35117
    Jake
    2011 tundra
    I can get some what would u like pictures of
  14. Apr 15, 2019 at 3:44 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Start at the bags then the wiring..
    Internet diagnosing is some new shit ! Lol
  15. Apr 15, 2019 at 3:46 PM
    Jjones35117
    Jake
    2011 tundra
    Ok I will. Just something I didn’t mention is that there are no wires going out to any switch that I can find. And I can’t find the switch to save my life.
  16. Apr 15, 2019 at 3:51 PM
    Jjones35117
    Jake
    2011 tundra
    Air bags and some of the wiring
  17. Apr 15, 2019 at 3:52 PM
    Jjones35117
    Jake
    2011 tundra
    Label and more wiring and compressor
  18. Apr 15, 2019 at 3:53 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Looks like that connector went to something that controlled the system, 2nd pic by frame.
  19. Apr 15, 2019 at 3:54 PM
    Jjones35117
    Jake
    2011 tundra
    Other part of label and what I think is the directional control valve
  20. Apr 15, 2019 at 3:54 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Wow, 2nd set of pics, thats a mess.
  21. Apr 15, 2019 at 3:54 PM
    Jjones35117
    Jake
    2011 tundra
    The second pic is of a relay
  22. Apr 15, 2019 at 3:55 PM
    Jjones35117
    Jake
    2011 tundra
    Yea if I can figure it out and get it working it I will clean it up
  23. Apr 15, 2019 at 3:56 PM
    Nm6300'asl
    2022 DC SR5 4x4
    I would replumb and protect all the wires, hoses, connectors.
  24. Apr 15, 2019 at 3:58 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Holy cow, the compressor is zip tied to the frame. You could just run new air lines and manual fill, cheap and easy.
    Edit: Sorry not frame, bed reinforcement.
  25. Apr 15, 2019 at 4:15 PM
    Jjones35117
    Jake
    2011 tundra
    I thought about running a toggle switch into the cab and using it to pump it up but I'm worried it will over fill
  26. Apr 15, 2019 at 4:44 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I would put 12 volts to that compressor and see if it even works.
    Better yet, start the truck and check to see if there is 12 volts going to the compressor.
  27. Apr 15, 2019 at 4:52 PM
    Porschetech29
    Francis
    Looks like the firestone ride rite wireless control kit. Definitely firestone bags and brackets. Look up the install instructions and figure out how the previous owner installed the system
  28. Apr 15, 2019 at 5:15 PM
    Jjones35117
    Jake
    2011 tundra
    Thanks man I’ve been trying to just get to a manufacturer so I could look up their stuff
  29. Apr 15, 2019 at 5:17 PM
    Jjones35117
    Jake
    2011 tundra
    So it looks like the ride rite has a remote not a switch is that correct
