2011 5.7 oil consumption ?
Discussion in '2nd Gen Tundras (2007-2013)' started by Waterproof2, Jun 5, 2014.
  1. Jun 5, 2014 at 6:06 PM
    Waterproof2
    Waterproof2 [OP] New Member
    Alex
    2011 Tundra 4x4 5.7
    Trd intake and sway bar
    I noticed I was losing around 3 to 4 quarts of oil between changes after 45000 miles . I mentioned that to the dealer they had to change the oil and do an oil consumption test after 1000 miles . They did the test today , 4 quarts low ?! They added 4 quarts and said to come back in another 1000 . Has anyone else had this issue ? 56,500 on the truck now .
  2. Jun 5, 2014 at 7:04 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    If there isn't a leak you should be worried about bad rings. That's one of the main reasons for oil loss. There is only 5.9 quarts so 3-4 is a massive amount and bound to be causing additional damage.
  3. Jun 5, 2014 at 7:22 PM
    andrew
    andrew where's the beer?
    andrew
    2012 rockwarrior
    stock
    I think we have 7.3 quarts?
  4. Jun 5, 2014 at 7:40 PM
    csuviper
    Broomfield, CO
    Oops yea your right. It's between 7.5 and 7.9.
  5. Jun 6, 2014 at 4:21 PM
    Mike Tread lightly.
    south carolina
    Op do you see any leaks under the truck? Does it smoke any when starting up cold?
    I will agree with csuviper on bad rings.... What i would do in a engine compression and look at the health of the engine...
  6. Jun 6, 2014 at 6:13 PM
    Waterproof2
    Alex
    2011 Tundra 4x4 5.7
    There are no leaks . The exhaust pipe has black soot like a diesel . It's still under warranty just wondering what they will do to fix it ? They said to bring it in every 1000 miles and they would fill the oil until 60,000 miles ...lol !
  7. Jun 6, 2014 at 6:17 PM
    Waterproof2
    Alex
    2011 Tundra 4x4 5.7
    I tried synthetic 0 - 20 and regular 5-20 same issue . I use it for work , a lot of max towing maybe I pushed it to hard ?
  8. Jun 6, 2014 at 9:15 PM
    csuviper
    Broomfield, CO
    Yea the oil is getting past the rings. I would push them to do something more about it.
  9. Jun 10, 2014 at 7:02 AM
    andrew
    andrew
    2012 rockwarrior
    stock
    How much did you tow? Well, they did tow a spaceshuttle so as long as you didn't tow anymore then that I'm going to say you're good.
    In reality, I don't think that towing over the limit would do it. I would think the tranny would go first unless you had the thing redlined all the time. I would go tell toyota to do new engine. I don't really trust dealerships so you might want to make them do it now before they try to pass the blame.
  10. Jun 10, 2014 at 5:56 PM
    WyoBull
    WyoBull New Member
    2007 Tundra DC 4x4 5.7 V8
    I have a 2007 DC 5.7 4X4 and I just changed my oil this past weekend at 60,000 miles. I use Mobil 1 5w20 and mine does not use any oil between changes, every 5,000 miles. Oh, that engine takes 7.4 quarts with a new filter.
    To heck with this oil test BS. Get your dealer to fix it it, period. For a 2011 to use oil like that and still be under warranty is definitely a problem.
  11. Jun 10, 2014 at 6:03 PM
    csuviper
    Broomfield, CO
    Def a problem!
  12. Jun 11, 2014 at 5:24 AM
    Waterproof2
    Alex
    2011 Tundra 4x4 5.7
    I'm
  13. Jun 11, 2014 at 5:26 AM
    Waterproof2
    Alex
    2011 Tundra 4x4 5.7
    I have to bring it in for a 2nd consumption test before they will fix it . ? They still won't say what the fix is . I just hope it doesn't run out before I get back . I really like the truck other than the oil BS .
  14. Jul 13, 2014 at 9:19 AM
    Jim-Bob
    Jim-Bob New Member
    2012 RCSB 5.7 4WD Silver Sky
    just bought it..just ordered TundraRacing Lowering Kit.. Then maybe 285/65 Nitto Terra's..havent decide on wheels..maybe 18 or 20 XD's..will do more mod's after reading more maybe on here..
    I'm definitely subscribing to see the outcome:eek:
  15. Aug 10, 2014 at 4:30 PM
    Bump for updates
    ODSteve likes this.
  16. May 16, 2015 at 11:46 AM
    ksmustange
    ksmustange New Member
    check out page 5 oil capacity you will be surprised even the dealers are in shock n awe go to google type in this 2011 toyota tundra product info LOOK ON PAGE 5 (PDF)bottom page oil capacity 5.7 takes 9.8 qt
  17. May 18, 2015 at 8:40 PM
    csuviper
    Broomfield, CO
