2011 4WD with stock suspension, 74k miles, its sqeaking/clunking like poltergeist.
Discussion in 'Suspension' started by Aron9000, Feb 19, 2020.
  1. Feb 19, 2020 at 11:17 PM
    Aron9000
    Aron9000 [OP] New Member
    Aaron
    Hate that my truck is clunking/squeaking at this early mileage. Its not horrible, as in EVERY SINGLE BIT OF THIS NOISE IS BELOW 25 MPH.
    The squeak part is going over pot-holes/speed bumps, I can get it to do that damn squeak if I jump up and down on the running board.
    Once again its at low speed, I also get some clunks/binding sound when I turn the truck in parking lot manuvers at under 10mph. Sounds a bit different than the clunks and squeaks I get at driving from 15-30mph driving over bumps.
    Seriously driving at 40mph over a rough road just shakes the truck to pieces and makes every single plastic part sqeak together.
  2. Feb 20, 2020 at 1:19 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Bushings are worn in one or more links or control arms.
    JLS in WA and johnnyskullface like this.
  3. Feb 20, 2020 at 2:20 AM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    I’m very new here ... but possible ball joints on the noisy side ?? Just thought
  4. Feb 23, 2020 at 7:26 PM
    What year and mileage? Possibly front sway bar bushings?
  5. Feb 23, 2020 at 7:35 PM
    johnnyskullface
    johnnyskullface New Member
    Beaverton, Oregon
    2018 White Tundra Limited Crewmax
    Second vote for control arm bushings. Also some squeaks can be as simple as a loose undercover.
  6. Feb 23, 2020 at 7:37 PM
    Grumpy Uncle
    Pat
    CO
    He mentioned those in the title.
  7. Feb 23, 2020 at 7:44 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    One squeak could be the AC condensor bushings, mine squeaked when shutting the door and small bumps. Lubed them and all bueno since then, probably 70k miles.
  8. Feb 23, 2020 at 7:45 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    This. It’s cheap to replace sway bar bushings at the same time.
