2010 tundra will not start
Discussion in '2nd Gen Tundras (2007-2013)' started by L_calvert, Feb 20, 2021.
  1. Feb 20, 2021 at 12:48 PM
    L_calvert
    L_calvert [OP] New Member
    Lee
    2010 toyota tundra
    I have a 2010 tundra. It showed a cylinder 2 misfire, so I changed all the spark plugs and the coil for cylinder 2. Now it shows codes that all of the cylinders are misfiring. It will turn over but will not start. I checked that fuel is getting to the engine and I tested all of the other coils with a multi meter. Could it be the ECM? any help would be appreciated.
  2. Feb 20, 2021 at 1:08 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome . Is it a 5.7 or 4.6 ?
  3. Feb 20, 2021 at 1:10 PM
    L_calvert
    Lee
    2010 toyota tundra
    It is a 4.6
  4. Feb 20, 2021 at 2:06 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    You could start by disconnecting the battery for a few minutes.
    While you are waiting, check connections. Check wires also.
    Rodent damage seems to be common this time of year.
  5. Feb 20, 2021 at 2:33 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I think you would have to troubleshoot the mechanical side first before you replace the ECM... Nothing like investing your kidneys on a problem that is not there.... Possible loose ground, or damaged ground??
  6. Feb 21, 2021 at 10:42 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    I hope that you used either Denso or NGK sparkplugs. Did you do the work with the battery connected? If so I agree with fixnfly on the battery disconnect for a few minutes. :smash:
