2010 tundra coolant/part help needed
Discussion in '2nd Gen Tundras (2007-2013)' started by BP207, Feb 25, 2020.
  1. Feb 25, 2020 at 3:35 PM
    BP207
    BP207 [OP] New Member
    Brandon
    2010 White Tundra SR5 5.7
    3/1 leveling kit flowmaster super 44 dual exhaust tinted windows
    hello all new member here and as well as being a new tundra owner. having read alot on the forum it seems that there is a great wealth of knowledge here. I dropped my truck off at a local garage today to have my new exhaust system installed, the shop is owned by a good friend and he gave the truck a thorough going over and he found coolant lines that need to be replaced ASAP! these are the coolant lines that run from the front of the motor along the right side of the motor and into the heater core. I cannot find a part number or diagram for these. I need both of they come as separate and I have tried online research but found nothing not to say I'm not familiar with the terminalogy. thank you!
  2. Feb 25, 2020 at 5:36 PM
    It might be these two. @Roman do these look like the heater core lines that he is looking for? I searched the 2010 SR5 with the 5.7. https://www.sparksparts.com/auto-pa...l-v8-gas-engine/hvac-cat/hoses-and-pipes-scat
    BP207[QUOTED][OP] likes this.
  3. Feb 26, 2020 at 4:37 AM
    BP207
    Brandon
  4. Feb 26, 2020 at 4:43 AM
    No problem at all. I beleive they are the inlet and outlet lines from the heater core. @Roman is everyone go to parts guy from one of the dealers so he will be able to verify it for you. He will see your request since he was tagged in the post. :thumbsup:
  5. Feb 26, 2020 at 4:56 AM
    BP207
    Brandon
    great thank you again!
  6. Feb 26, 2020 at 6:53 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    vhstejskal and Wynnded like this.
  7. Feb 26, 2020 at 7:07 AM
    BP207
    Brandon
    thank you for the diagram! it looks like it's the pnc 16206 if it is a complete assembly. a better description is that it is metal tubing that connects on the passenger side of motor near water pump and they are supported with clamp/mounts onto the motor itself and run back parallel to the rubber sections of hose from the heater core. does that sound correct? and by chance have a link to purchase providing that's the part number I believe it is? thank you in advance
  8. Feb 26, 2020 at 7:16 AM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    I buy a lot of my OEM parts from McGeorge and they have slightly better prices than Ultimate but you'll want to check shipping costs. (I usually wait until I need a lot of stuff before ordering since shipping isn't cheap) https://toyotaparts.mcgeorgetoyota.com/
    Wynnded and BP207[OP] like this.
  9. Feb 26, 2020 at 7:18 AM
    Roman
    Roman
    Franklin, TN
    BP207[OP] likes this.
  10. Feb 26, 2020 at 7:32 AM
    BP207
    Brandon
  11. Feb 26, 2020 at 8:36 AM
    Roman
    Roman
    Franklin, TN
    Yes, it comes made together.
  12. Feb 26, 2020 at 9:55 AM
    BP207
    Brandon
    thank you I just ordered it under $90 with shipping not too bad!
    Roman[QUOTED] likes this.
