2010 transmission codes p2714 & p0761
Discussion in '2nd Gen Tundras (2007-2013)' started by 2010tundrazac, Jul 11, 2024.
  1. May 4, 2025 at 11:40 AM
    Eeck62
    Eeck62 New Member
    Erik
    2010 Tundra Crewmax, 5.7L
    Mdl and TundraDude772, thank you guys for all the info, that's a hug help! Just finished up a bunch of shift work so getting back into this now!
  2. May 25, 2025 at 8:47 AM
    j6y
    j6y Recovering Perfectionist
    16’ Moby Dick
    For those have you that have problem solved on Solenoids, did you use TS at all? and were there any features that helped isolate a solenoid?
    I've tested them with the on/off feature and on the SLU and SLT the 'clicks' aren't very loud compared to the S1 > S4 but they all function. ON and OFF
    Checking the voltage would be a good move but it doesn't look like TS can show/display that data? Any input or tool recommendations would be appreciated, trying to narrow down a 'D stuck off' with minor very inconsistent symptoms.
  3. May 25, 2025 at 2:50 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Start by changing your fluid. I trplaced the solenoid, 4 different ones in total, and they came back a year later, right when the fluid change was due. I've been changing my oil every 15- 20k miles since I last dropped the pan.
    j6y[QUOTED] likes this.
  4. May 25, 2025 at 8:23 PM
    j6y
    16’ Moby Dick
    The first thing I did was a drain and fill (once) and it got better but I'm more than sure the SLT is on its way out but when it gets hot. I'd like to find a way to test it in place because I know that I might be dealing with broken bolts and trying to minimize down time.
    Once the TC locks up it shifts perfectly so it points to the SLT and not the SLU
    What codes did you get and what solenoids did you end up replacing?
  5. May 26, 2025 at 5:11 PM
    blackdemon_tt
    I replaced the clutch control, TC solenoid, performace D and C
    I snapped 2 bolts on the rear corners and left them as is. No leaks, been over a year.
  6. May 27, 2025 at 3:30 PM
    blackdemon_tt
    Btw, only reason I changed the clutch and C solenoid is because I would clear the codes and as soon as I turned the truck on they would come back, like the Terminator.
    j6y likes this.
  7. May 28, 2025 at 8:44 PM
    j6y
    16’ Moby Dick
    Thanks for your input it's much appreciated! So your transmission is still running great?
  8. May 29, 2025 at 1:34 PM
    blackdemon_tt
    Yes, 312k currently just took a round trip to Pasadena from the Antelope Valley with some mountain climbs inbetween.
    j6y likes this.
  9. May 29, 2025 at 7:55 PM
    j6y
    16’ Moby Dick
    Awesome! This give me the motivation to tackle mine, thanks.
    blackdemon_tt likes this.
