2008 tundra- Key won’t turn in ignition
Discussion in '2nd Gen Tundras (2007-2013)' started by Nv169, Oct 25, 2024.
  1. Oct 25, 2024 at 5:29 AM
    Nv169
    Nv169 [OP] New Member
    2008 white tundra
    I put my key in the ignition and it will not turn at all. I was thinking maybe the steering wheel was locked so I wiggled it and the key simultaneously. Nothing. Then I turn my wheel more and it locked. I try the same thing again and get the same results. Not sure if it’s the key, the ignition itself, the lock, etc. Also when the key is in and door is open it doesn’t always “chime”. You have to push and hold the key or get it in the “right spot”. If that makes sense. What do y’all think?
  2. Oct 26, 2024 at 4:08 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    You need a new key...what about the spare?
    Nv169[OP] likes this.
  3. Oct 28, 2024 at 10:17 AM
    Nv169
    2008 white tundra
    It ended up being the main key was worn. I got a new one cut.
