2008 Tundra front speaker replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by wchang23, May 14, 2021.
  1. May 14, 2021 at 9:24 AM
    wchang23
    wchang23 [OP] New Member
    William
    2008 Tundra SR5
    20-inch aftermarket rims
    Hello,
    I have a 2008 Toyota Tundra and the front speakers in the door are blown. When replacing them do I get round car speakers that are 6 1/2 inch size? Will I need any special adapter or wire harness or will the aftermarket speakers plug and play?
  2. May 14, 2021 at 9:41 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    1lowlife likes this.
  3. May 14, 2021 at 9:49 AM
    wchang23
    William
    2008 Tundra SR5
    Thanks for the link. I am in the US and prefer to purchase locally.
    From the link above the 2008 Tundra has a 6x9 size front speaker? Do I need anything additional or just get this size speaker and plug and play?
  4. May 14, 2021 at 9:50 AM
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
    You can either cut the factory connector plug off and use the 2 wires directly to your new speakers or you can buy the adaptors for $10-15 and save the factory plugs
  5. May 14, 2021 at 10:08 AM
    audiowize
    Paul B.
    If you just buy a 6x9 speaker and try to make it fill the hole in the door, your window will hit it when you roll it down and it will sit back an inch or two from the door panel, which is why I recommended the Toyota specific Focal set, which I'm sure you could purchase locally.
    Buying the Toyota specific speaker set will also prevent you from needing to cut wires (don't do this!) or purchase extra plug harnesses.
    If you want to use a generic 6x9 speaker, you will need to purchase spacers specific to the Tundra, wiring pigtails that can plug into your harness, and 6x9 drivers. If you get full range 6x9 drivers, you may also want to disconnect any other dash/pillar midrange/tweeter speakers that you have.
    Another option is just getting some used pulls from a junkyard.
  6. May 14, 2021 at 10:28 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Purchased these locally.. incredible sound but a tight fit with a little trimming of the inside door panel and dash covers.. The magnets will be against the window guide but doesn’t effect the window movement..Factory wires... you just need the plug harness adapter for the 3.5’s..a good audio store should be able to hook you up.
    https://www.hertzaudiovideo.com/car-audio-coaxials-dieci-dcx87_3/
    https://www.hertzaudiovideo.com/car-audio-coaxials-dieci-dcx690_3/
