2008 Toyota Tundra Rear Differential Oil Change
Discussion in '2nd Gen Tundras (2007-2013)' started by wchang23, May 5, 2021.
  1. May 5, 2021 at 10:48 AM
    wchang23
    wchang23 [OP] New Member
    William
    2008 Tundra SR5
    20-inch aftermarket rims
    Hi,
    I have a 2008 Toyota Tundra 2WD. I recently purchased this pre-owned truck and I would like to change the differential oil. Since this is a 2WD I only need to change the rear differential? Also, would four quarts of oil be the correct amount? Please also let me know if the following oil weight is fine to use? I am planning to purchase this from Walmart - Super Tech Full Synthetic Gear 75W-90
  2. May 5, 2021 at 1:22 PM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    I used 3-3,75L 75W90 in my 2010 tundra RWD
    Google it and you will find out , I only know the Dutch websites to check it out via licence plate number
    hope it helps you ...
  3. May 5, 2021 at 1:50 PM
    timsp8
    NY
    About 4 is correct. The rear diff is the easiest oil to change. No measuring. Just drain and refill. Make sure the fill hole with come loose before draining. I’ve read where some wouldn’t come loose. Or else you’ll have to turn the truck upside down to fill it.
  4. May 5, 2021 at 2:13 PM
    SouthWestGA
    SouthWestGA New Member
    I used the same oil as you did on my 07 CrewMAX
    super tech 75-90
    I used almost all 4qts
    as others have said loosen the fill plug FIRST
    Then drain plug
    squirt it in till it pours out then button it up
    More is better than not enough lol
    you can watch YouTube videos if you’re interested
  5. May 5, 2021 at 2:18 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  6. May 9, 2021 at 5:48 PM
    12platinumBarge
    12platinumBarge New Member
    2012 platinum tundra
    75W..4 quarts
    And yess
    VERY IMPORTANT... get the fill cap open before u drain the system.
