2008 Sequoia platinum build- Tundra friendly mods
Discussion in 'Sequoia Builds' started by Beau, Dec 7, 2019.
  1. Apr 20, 2020 at 11:24 AM
    #181
    Beau
    Beau [OP] De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Any of these will work. All the ec002 systems are the same except for the remotes and push buttons. Hope this answers the question. I believe that the link is also in the earlier threads too.
  2. Apr 20, 2020 at 11:27 AM
    #182
    STEEV11
    STEEV11 New Member
    2011 Platinum - 55k Miles
    Rev Tech lift - Bilstein 5100 - N-Fab LED mounts
    Beau, What shocks are you running on the rear?
  3. Apr 20, 2020 at 11:41 AM
    #183
    STEEV11
    STEEV11 New Member
    I am getting a high speed vibration on my Tree when I get to 80 mph. I have replaced the following parts with no success. (Tie rods inner & Outer - Rack and Pinion - Brakes - Calipers - Rims and Tires - Shocks - Springs)
    The vibration is worse on the passenger side of the car. I have jacked it up and looked at it but don't see anything that would be causing this. My next step is to replace the upper and lower ball joints plus the wheel bearings.
    Any thoughts on what could cause this would be helpful.
  4. Apr 20, 2020 at 1:01 PM
    #184
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    He has a platinum. You can adjust the sensor in the rear to get a lift.
    STEEV11[QUOTED] likes this.
  5. Apr 20, 2020 at 1:57 PM
    #185
    STEEV11
    STEEV11 New Member
    The sensor will get you 2 inches maybe 2.5 - Once you do that the ride quality goes to shit because your airbags are fully inflated. I am looking to add a 1-inch shock extender and an airbag spacer to get my ride quality back. In doing this I want to upgrade my rear shocks as well. I am looking at the bilsteins 5100 since this is what I have in the front.
    If anyone else has swapped out their rear shocks on a lifted Sequoia please let me know which brand you went with and why.
    omgboost likes this.
  6. Apr 20, 2020 at 3:50 PM
    #186
    Beau
    Beau
    Yep, I’m running the stock suspension. I’ve never had any issues to warrant me looking into other options.
  7. May 5, 2020 at 1:23 PM
    #187
    Toy2008
    Toy2008 New Member
    2008 white Toyota Sequoia
    hi It looks awesome , I have a platinum 2008 With chrome mirrors. And I want to go for the white pearl color .
    And the guys at the dealer are telling it’s impossible to change the chrome for white pearl I’ll have to change the entire mirror , and I ask him ok let change it and they say impossible it will not fit only 2008 you can’t change the covers .
    can you tell me what did you did please I appreciate it.
    thanks again
  8. May 5, 2020 at 4:09 PM
    #188
    Beau
    Beau
    Hey. You can definitely change just the mirror covers, but the dealer is right about not having any pearl white ones. Also, our pearl white is different than the new pearl. Ours is called Arctic frost pearl and the new color (like war's wife) is called blizzard pearl. At any rate, you have 2 options. Paint or vinyl wrap. For the time being, I chose the later and will eventually have my mirrors and grill painted to match. The color I used was this. It is some of the easiest vinyl that I have used to wrap with. The color is off slightly, but overall it looks pretty good. My grill, mirrors, and rear plate are wrapped with it. Hope this helps..
  9. May 5, 2020 at 4:11 PM
    #189
    Toy2008
    Toy2008 New Member
    You’re right I’ll paint them .
    dontou have the part number you order?
  10. May 5, 2020 at 4:15 PM
    #190
    Beau
    Beau
    Part number for what? Confused
  11. May 5, 2020 at 4:17 PM
    #191
    Toy2008
    Toy2008 New Member
    Sorry I’ve confused chats.
    I’ll order them in white and paint match.
    thanks again
  12. May 5, 2020 at 4:20 PM
    #192
    Beau
    Beau
    No worr
    No worries, if you are going to paint, you may as well just paint the chrome to save some money. Also, pearl is very hard to get right. It’s a 3 part process from what I understand. That’s why I went with the wrap. Post back with your results! I’m interested:)
  13. May 5, 2020 at 5:14 PM
    #193
    Toy2008
    Toy2008 New Member
    Thanks.
    mill ask the paint guy what’s easier for him paint chrome or paint regular covers
  14. May 9, 2020 at 10:13 AM
    #194
    Sequoiar
    Sequoiar New Member
    painting over paint (not chrome) easier. Or, I've had good luck with the "Spray Max" custom blended paint & clear coat finish on ebay ~ $50 for the two cans. Prep work matters, but easy. 800grit 1000grit, 1500grit & 2000 for the clearcoat if you wish. You need a n-95 respirator which may be hard to get now.
    I've done my Tacoma fuel door replacement, a BMW spoiler, and a Replacement Sequoia grill for a fraction of what body shop wanted.
  15. May 10, 2020 at 6:17 PM
    #195
    Toy2008
    Toy2008 New Member
    Thanks you very much
  16. May 10, 2020 at 7:23 PM
    #196
    Toy2008
    Toy2008 New Member
    youre taillights look awesome what do I need to buy to do them?
    Is it easy? I’m a 1st timer
  17. May 10, 2020 at 7:26 PM
    #197
    Toy2008
    Toy2008 New Member
    hello it
    Looks awesome how
    Can k do that to my sequoia emblem part?
    There are 2 pieces se black one and the white one with seqouia letters Can it be taken apart?
    Did you wrapped them?
    Thanks
  18. May 10, 2020 at 7:30 PM
    #198
    Toy2008
    Toy2008 New Member
    looks awesome how did you did the rear lettering insert?
    Is it like dealer kit?
  19. May 11, 2020 at 6:13 PM
    #199
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Insert are double sided taped. Clean inside real good. I recommend doing when it's hot out. It will stick so much better
    I did it when it was like 30 degree out and well, one of the letter started to lift off. Had to use a heat gun to get it to stick back down.
    Use alcohol wipe if you have them, it should come with your lettering. Clean, wipe, dry, stick. Done.
    I got mine from these people:
    https://www.bdtrims.com/Rear-Door-Plastic-Letters-Inserts-for-2008-2019-Toyota-Sequoia-Models
    Got the domed or raised version. Dont like the flat one.
  20. May 11, 2020 at 6:15 PM
    #200
    BrandonL812
    Brandon
    Im was a first timer too. Far away look good but up closed, not great. Air bubble and tear, split here and there.
    I got the vinyl from Amazon where @Beau had posted link. Soap and water, heat gun or hair dryer.
    Then i watched some youtube vids about vinyl wrap taillight and went for it.
  21. May 11, 2020 at 6:56 PM
    #201
    Beau
    Beau
    Yes, I detailed it in an earlier post I believe but essentially I wrapped the frame in matte black and insert in pearl white. The actual "sequoia" letters are the third piece to the puzzle and are the ABS plastic ones from Amazon. This piece is definitely one of my favorite looking mods on the truck, it really stands out and makes the truck look newer.
  22. May 12, 2020 at 7:07 PM
    #202
    Cody65
    Cody65 New Member
    Question, did your original have the buttons and knobs on the side of the stereo? And the new unit replaced all that? And wiring in the wires less charger, did that go into the back of the cigarette lighter plug in?
    thanks for the post, I just got an 08 platinum as well.
  23. May 12, 2020 at 7:14 PM
    #203
    Beau
    Beau
    Welcome! First off, if you are thinking about doing the radio...do it! It was the best mod I've done to date. Yes, my original stereo was the stock JBL unit with the knobs and buttons on the sides. This unit and the additional hardware replaced it. You will need the dash kit and Maestro unit to make it just about plug and play. I had Best Buy do it since it was free install. The wireless charger is just using a cig outlet that I disconnected and tucked behind the panel. I believe that is detailed in one of the earlier pages of this thread. Hope this helps!
  24. May 12, 2020 at 9:02 PM
    #204
    Toy2008
    Toy2008 New Member
    Beau[QUOTED][OP] likes this.
  25. May 12, 2020 at 9:28 PM
    #205
    Beau
    Beau
  26. May 14, 2020 at 6:48 PM
    #206
    Toy2008
    Toy2008 New Member
    BrandonL812 and Beau[QUOTED][OP] like this.
  27. May 14, 2020 at 7:23 PM
    #207
    Beau
    Beau
    I look forward to seeing the results! Good luck:)
  28. May 15, 2020 at 7:33 PM
    #208
    Beau
    Beau
    Finally got a chance to strip the weathered pinstripe. The Rhino in the background has taken both my free time for repairs and leisure. At any rate, thanks to @TheBeast for recommending the whizzy wheel. For those that haven't used one of these decal erasers, they work well but can cause some issues. I burnt through some of the clear in one spot, so be careful with the speed! Overall, I think that it looks WAY better and I am glad that I did it.
  29. May 15, 2020 at 8:27 PM
    #209
    Toy2008
    Toy2008 New Member
    Sorry what did you erased?
  30. May 15, 2020 at 8:56 PM
    #210
    TheBeast The Beach
    looks clean ! much better ! yes low speed on the drill and keep moving, don't stay on the same spot.
    Beau[OP] likes this.
