2008 brake secret?
Discussion in '2nd Gen Tundras (2007-2013)' started by ChuckT17, Nov 11, 2015.
  1. Nov 11, 2015 at 12:32 PM
    ChuckT17
    ChuckT17 [OP] New Member
    Chuck
    '08 CrewCab
    Is there a secret to getting good brakes on my '08 Tundra?
    At 120,000 miles I had the brakes redone, all 4 corners, new pads and turned down the rotors.
    Afterward I expected the brakes to be "like new" (ha!) - the brake pedal was soft, mushy and pulsed.
    Took it back had them drain, refill with fresh, and bleed.
    Still soft, mushy and pulsing.
    Took it back.
    They turned the front rotors again ("you wife must have had the Towing control set wrong").
    Still soft, mushy and pulsed.
    Took it to a different shop. Had them replace Front (only) rotors and pads.
    Better but still soft and mushy.
    So ... before I do anything else is there a secret sauce to Tundra brakes?
    OEM fluid?
    Bleeding the system at a hidden fitting?
    Any help?
    cvt
  2. Nov 11, 2015 at 12:40 PM
  3. Nov 11, 2015 at 12:48 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Sounds like the shop that turned the rotors did a Shitty job because it still pulsed. Then rotors were replaced and pulsing went away. Oem pads?
  4. Nov 11, 2015 at 12:52 PM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Also sounds like a crappy brake bleed job...
    AnonVet likes this.
  5. Nov 11, 2015 at 7:35 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I'd replace the rotors. Not all rotors can be successfully turned and it isn't really that expensive to change them. 2nd, Go not back to this mechanic. They should never let it out of their hands with soft/mushy brake pedal.
  6. Nov 11, 2015 at 8:48 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm no brake expert, but when it's time for brakes I always go with new pads and new rotors. I go with a quality pad like Hawk or something similar. It seems that a lot of places sell brake pads with a lifetime warranty, which in my opinion means the compound of the pad has to be really hard. What ends up happening is the pads don't wear but the rotors wear and warp as a result of the crappy pads.
    If your driving style (heavy foot or towing) or conditions (long steep declines) are heating your brakes too.much, maybe try slotted/cross drilled rotors on the front to stay a bit cooler?
    Like you said, if your brakes feel mushy the brake fluid probably needs to be bled. If it was done maybe it was done incorrectly.
    Black Wolf likes this.
  7. Nov 12, 2015 at 6:33 AM
    I went the same route. New rotors and pads all the way around.
    MotoTundra[QUOTED] likes this.
  8. Nov 12, 2015 at 7:48 AM
    15whtrd
    15whtrd Mr. Blonde
    How about the brake hoses. Sounds like a good time to change them out for some braided hoses. That can cause some sponginess too.
    Sefferston likes this.
  9. Nov 12, 2015 at 10:04 AM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Steel braided will reduce some squishyness, but if the lines aren't bled correctly then the squishyness will be there. You can use a brake bleed kit, but personally, I like doing the old fashion way of press press hold. Takes 2 people but always worked for me.
    Start furthest away from the MC, then work your way towards it. Do that twice while making sure the MC is constantly filled, should be good to go after that.
    Black Wolf, 15whtrd and TruckLife900 like this.
  10. Nov 12, 2015 at 10:18 AM
    TruckLife900
    2013 White SR5
    ^^^^^^^Exactly :thumbsup:
    I like to alternate brake fluid colors (ATE blue then amber/gold) between bleeds - that way I know when I've pushed all the old fluid completely thru. Problem is blue isn't being sold in the US anymore :confused:.
    jberry813 likes this.
  11. Nov 12, 2015 at 10:39 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    How often are you bleeding your brakes?
  12. Nov 12, 2015 at 10:47 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    What?
    I guess if your truck only lives for 5 years. I bleed mine every 2 years. Moisture will get in the brake system no matter what and deteriorates fluid, especially dot4. Spirited driving (and braking) exacerbates the problem.
    Sefferston and TruckLife900 like this.
  13. Nov 12, 2015 at 10:48 AM
    15whtrd
    15whtrd Mr. Blonde
    I think you're supposed to do it every 2-3 years. I flush my brake fluid every time I change the pads on my vehicles.
  14. Nov 12, 2015 at 10:53 AM
    csuviper
    Broomfield, CO
    Lol. I deleted that extra part before you posted. I see recommendations are between 2 and 3 years for various manufacturers. I have only done a full brake fluid change once in all the vehicles i have owned. Guess i never had each of them more than 4-5 years anyway. I will have to add this to the maintenance schedule then. I will go for every 2-3 years depending on feel of the brake system.
    http://www.aa1car.com/library/bfluid.htm
  15. Nov 12, 2015 at 10:59 AM
    TruckLife900
    2013 White SR5
    I always do a fresh bleed before any track days. If you ever do any track day activities tech inspection will check your fluid among another things... boiling brake fluid is a bad day. :boom:
  16. Nov 12, 2015 at 11:24 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    In a dry ass climate like ours, the brake fluid stays decent for quite some time. I rarely flush vehicle unless the system was comprimized some how. Normally a bleed does just fine.
    Most do not drive as "spirited" as jberry....
  17. Nov 19, 2016 at 9:43 AM
    ChuckT17
    Chuck
    '08 CrewCab
    Revisiting this topic.
    Firstly I can easily recall when "high performance" cars were recommended (this was in an owner's manual) to have their brake fluid drained, then the system flushed with alcohol (methyl?) and refilled and bled with fresh brake fluid every 2 yrs/36k miles. The alcohol would absorb any water and the flushing would purge contaminates.
    Secondly I have seen a discussion about brake system proportioning valve body that frankly said it was overlooked by most shops because the procedure was more involved than they cared to commit to and was an addtitional expense to the customer. I read that as hard to do properly and hard to justify.
    Well I think a complete drain, flush, and refill probably would accomplish what the alcohol flush was meant for.
    But what about that proportioning valve bleed (Toyota most likely has a more sophisticated name for the item) has anybody encountered, tried that?
    I'm still unimpressed by our Tundra's brakes (at 147k miles). When the truck was new they were noticeably better than they are now. And I've had the rotors replaced, shoes replaced, even the master cylinder replaced. They still (currently) feel more like a bucket of stiff Oatmeal than I believe they shoud.
    Opinions? Comments?
  18. Nov 19, 2016 at 10:31 AM
    Leakypunt
    Leakypunt New Member
    White 2015 TRD W/Chrome
    I also have 2015 Tundra with spongy brakes. Pads and rotors ingood condition as only 40k kms on the truck. Seems like air inside but no brake work has ever been done?? Any ideas??
  19. Nov 19, 2016 at 10:59 AM
    ChuckT17
    Chuck
    '08 CrewCab
    Hey I'm in the same boat.
    Next thing left to change is the flex lines, 2 on front 4 in rear. Estimate $300.00.
    Blech!
    As I said _above? I've encountered several (3?) accounts that suggest that the proportioning valve needs to be bled and shops aren't doing it.
  20. Nov 19, 2016 at 4:16 PM
    Leakypunt
    Just read on another forum to bleed the air fromthe VSC assembly using techstream. Anyone tried that?
  21. Nov 19, 2016 at 5:40 PM
    ChuckT17
    Chuck
    '08 CrewCab
    Can do that without special tools?
  22. Nov 20, 2016 at 6:28 AM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    I've done it. Air bleeding with the Techstream can be useful in determining if there was air in the lines to begin with. Depending on model, it can force a steady flow of fluid through the line. If you are using a clear bleeder hose then you can see if there is any air.
  23. Nov 29, 2020 at 2:35 PM
    Jsomar
    Jsomar New Member
    Had the same problem. Changed the brake bleed nipples added some Teflon and problem solved.
