2008 5.7 CMAX Check engine light, anti skid, VSC flashing lights
Discussion in '2nd Gen Tundras (2007-2013)' started by Jettech, Oct 23, 2017.
  1. Oct 23, 2017 at 8:35 AM
    Jettech
    Jettech [OP] New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    Truck is on the wait list for the shop but trying to get an idea of what is going on in case they try to pull some BS. 2008 5.7 122000 miles. Engine light, VSC, Trac control flashing driving down the road. Pulled codes to find
    C1201- Engine control system malfunction
    P0101- Mass or colume air flow A circuit / range/ performance
    I'm reading all kinds of different issues pertaining to these codes but the worst one linking them to the air injection pump. I disconnected battery for 10 min and it reset system. All lights came back on after 50+ miles of driving. Any thoughts?
    Jsena likes this.
  2. Oct 23, 2017 at 8:51 AM
    TheBeast The Beach
    AIP maybe.If so, there is an extended warranty from Toyota on those. I think 150K/10 years so you might still be covered if that's the case.
    could also be ABS sensor. Read up on the forums, plenty of similar issues.
  3. Oct 23, 2017 at 9:32 AM
    AIP. Get a bypass kit if you can’t get it covered.
    Kubeanie likes this.
  4. Oct 23, 2017 at 9:34 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Pull the cables fromyour battery and put it back in. Wait 15 mins before you put them back.. mine did that a month ago and I did that, and I never seen it again
  5. Oct 23, 2017 at 9:35 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Never mind, just read the bottom that you already did that :eek: still doing it ?
  6. Oct 23, 2017 at 9:38 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Worth a try: check to make sure that air hose (from the intake unit to the engine) didn't come off. That was what happened to me this summer (pretty much the same symptom). No issues after tightening it.
    Wynnded likes this.
  7. Oct 24, 2017 at 2:51 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Started the truck this morning and all lights were not on the dash. Nothing changed other than its been one of the coldest mornings we have had at 45 degrees. Not sure what to do now and Im not really wanting to just wait until they come on again. Still have the service appt scheduled but not sure if they will find anything since the check engine light is off.
    DalTee likes this.
  8. Oct 24, 2017 at 3:47 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    I did check the hose on the intake and its connected. No issues there.
  9. Oct 24, 2017 at 4:05 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    5.7 Non Flex
    GNTundra likes this.
  10. Nov 6, 2017 at 5:02 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Picked up the Tundra from the repair shop. Problem was the mass air flow sensor. Had to pay the $250 deductible for my extended warranty to replace a $65.00 part but its now fixed I guess. I still cannot find the answer to the question of why the check engine light and blinking traction lights when a simple glitch with the mass air sensor.
  11. Nov 12, 2017 at 2:24 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Yep temperature dropped here too - it was 27 degrees yesterday.
  12. Nov 12, 2017 at 2:26 AM
    DalTee
    DalTee New Member
    Dal
    Those flashing lights really freak me out.
  13. Nov 13, 2017 at 5:25 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Am having the same problem.......ggggggrrrrrrrr
    VSC and traction light on
  14. Nov 13, 2017 at 6:40 PM
    Les7311
    I don’t get it. How does the mass air flow sensor affect the VSC and traction control???
    Plus I don’t have any codes....
  15. Nov 13, 2017 at 7:05 PM
    TheBeast The Beach
  16. Nov 13, 2017 at 7:14 PM
    Les7311
    Excuse my not knowing. What is AIP?
    You tube is all over the place with fixes. Don’t want to spend if I can fix
  17. Nov 15, 2017 at 5:13 PM
    DalTee
    DalTee New Member
    Dal
    Air injection pump
  18. Nov 15, 2017 at 6:25 PM
    Les7311
    Resolved.
    The 7.5amp for the ECU was blown....
    TheBeast likes this.
  19. Jan 28, 2018 at 8:35 AM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Lights are back on again. Mass air flow sensor code. It was replaced with a new part and still coming on at random. Clear the code and a week or 2 go by and shes back on again. Starting to get a bit annoying. Anyone with an idea I can try???
  20. Feb 10, 2019 at 9:36 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    I had a check engine light come on then later traction control off light and a flashing 4LO light. I took it to Auto Zone and got a diagnostic report. I cleaned the MAFS, however it looked spotless and I checked the intake tubing and noticed a section came apart. Put it back together and everything was fine.
    Jsena likes this.
  21. Feb 14, 2019 at 9:19 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Did yoy have your air breather off or open at any part while engie was running? If so disconnect battery for 30 min it should rest.
  22. Feb 14, 2019 at 9:44 PM
    Red Freighter
    Oregon City
  23. Feb 14, 2019 at 9:48 PM
    Vince
    Vince New Member
    Vincent
    That is your problem I did the sea foam treatment to the intake and the breather boot came off. Took it for a drive and check engine light and 4lo light flashing remove neg terminal and went in the store hooked back up and all lights were gone. Try that before the shop.
  24. Aug 6, 2020 at 6:24 AM
    ned irish
    ned irish New Member
    Ned
    2006 Toyota Sequoia
    I'm not sure if this will help but it worked for my 2006 Sequoia. I ran into multiple OBDII failures featuring MAF and all 4 Oxygen Sensors having under/low voltage and had a sputtering truck that occasionally stalled and the codes wouldn't reset, it's important to review all of the above fixes. But take a few seconds and try an additional one. First off. after reading forums from many different sites, I cleaned the Mass Air Flow sensor and changed the air filter. It didn't fix it. I replaced the MAF and that didn't fix it. I swapped some relays around and the problem persisted. I removed the battery cables, cleaned the terminals, cleaned the connecters and inspected the battery cables for fraying and proper connection to the frame and fender - still no luck.
    I had difficulty believing that the MAF and all 4 Oxygen Sensors went at once. The error code bothered me that it was "low voltage" so before I brought the truck to a dealer or repair shop, I decided to check ALL of the fuses in the vehicle. As luck would have it, one of the last (of course) fuses I checked was the EFI2 10amp fuse under the hood and it was blown. On a 2006 Toyota Sequoia it is located under the hood on the driver's side in the larger of the two fuse boxes (there is a third box marked as RELAYS) and the fuses are diagrammed under the cover for the fuses. Replacing the 10 Cent fuse fixed the problem! And probably saved me hundreds of dollars to diagnose the problem. This fix may not be your issue, but it takes 15 seconds to check and is a cheap fix if it is just a blown fuse. Cheers!
