2007 Tundra with 3000 miles - computer codes going crazy - help please
Discussion in '2nd Gen Tundras (2007-2013)' started by LAK, Aug 5, 2021.
  1. Aug 5, 2021 at 1:00 PM
    LAK
    LAK [OP] New Member
    Leslie
    2007 Tundra
    I am posting this out of desperation in the hopes that someone can help me find a Master Technician or ' Wire Wizard' within 300 miles of Lake Havasu City to have our 2007 Toyota Tundra computer looked at and fixed or replaced.
    We have a show truck (engine not modified) - cosmetic modifications only - that has 3000 miles on it and is driven less than 100 miles a year. We started it last week and various sensors came on. After reviewing all of the forums, we see that this is a pretty common problem on this generation of Tundra.
    I know we will need to have the truck towed to someone who knows what they are doing and has some experience in this area, but don't know how to find this person. Anyone out there know of a person who can either fix or replace this computer/sensors without ongoing $$$ drain? I have contacted Toyota - no help whatsoever.... they don't even know which dealership (s) have master technicians. Private but talented wizard would be great too.
    We can take the truck to SoCal/Orange County or Phoenix Metro.... would really appreciate any referrals here.
    Thank you,
    Leslie
  2. Aug 5, 2021 at 1:02 PM
    Kanobi13
    Kanobi13 New Member
    Welcome.
    :worthless:
  3. Aug 5, 2021 at 1:12 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Toyota corp is not going to have your answers. Have you contacted any local toyota dealerships? That is where I would start. They can at least help and read/identify the codes being thrown. You need to know what codes are active as a starting point.
    NewImprovedRon and LAK[OP] like this.
  4. Aug 5, 2021 at 1:26 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Great year Tundra for sure. I hope you get the needed help.
    Does it have the 5.7 or 4.6 Engine? Or possibly V6. You may or may not be aware that the 4.6 has a timing belt that could be an issue - from age not mileage.
    LAK[OP] likes this.
  5. Aug 5, 2021 at 1:59 PM
    SouthWestGA
    SouthWestGA New Member
    5.7 and 4.6 are chain engines
    4.7 engine is a carryover from the first gens until it was phased out
    4.7 have timing belts
    LAK[OP] likes this.
  6. Aug 5, 2021 at 2:06 PM
    Trooper2
    JR
    Thanks for that clarification.
    LAK[OP] likes this.
  7. Aug 5, 2021 at 2:10 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    What do you mean? Sensors are electrical devices that report data to the vehicle's computer. Normally you would be unaware of whether they are on or off. Do you mean that you have lights on the dash lighting up that aren't normally? If so which ones? Are they flashing?
    Depending on what's going on, you could have something as simple as a bad battery. You haven't given any information to know what the problem even is.
    Depending on what's going on, you may simply be able to buy this:
    https://www.amazon.com/Autel-AutoLi...d=1628197794&sr=8-4-spons&smid=A3MNQOSQ336D3K
    Plug it into the OBD port on your truck, turn the key to the second position, then read the codes and let us know what they are.
    Again though, you could have something very, very, very minor going on.
    LAK[QUOTED][OP] likes this.
  8. Aug 6, 2021 at 3:09 AM
    LAK
    LAK [OP] New Member
    Leslie
    2007 Tundra
    2007 Toyota Tundra SR5 double cab 5.7 engine
    3000 miles
    Starts and runs fine
    Symptoms:
    Check Engine Light continuously on
    4Lo flashing
    Slippery when wet light continuously on
    VSC light flashing
    This light combination is all over the Internet.
    Codes tested and found: P0102
    Mass or Volume Air Flow A Circuit low.
    Cleaned Mass Air Flow sensor / no change
    Removed positive battery cable for 1 hour / no change
  9. Aug 6, 2021 at 3:10 AM
    LAK
    LAK [OP] New Member
    Leslie
    2007 Tundra
    Thank you.
  10. Aug 6, 2021 at 4:54 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Any sighs of mice?
    LAK[OP] likes this.
  11. Aug 6, 2021 at 5:10 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    Virginia Beach
    2021 CrewMax TRD OffRoad
    Stock for now
    I'm going to go out a limb here, buy you might want to start researching AIP by-pass kits.
    Adam and LAK[OP] like this.
  12. Aug 6, 2021 at 6:23 AM
    audiowize
    Paul B.
    Thank you for providing that information, that's much more specific, especially that you already tried cleaning the MAF sensor.
    It's a reasonably expensive part to just guess at a replacement, but at the same time Toyota used this sensor on a ton of vehicles, and if you buy a pull from a yard it's a $20 gamble instead of a $100 gamble. Here's an example of one source: https://www.ebay.com/itm/273687406913?epid=654640046&LH_ItemCondition=3000
    It's conceivable that a clogged air filter could set this off too, though that seems very unlikely.
    Dalandshark likes this.
  13. Aug 6, 2021 at 8:40 AM
    LAK
    LAK [OP] New Member
    Leslie
    2007 Tundra
    I don't know how to individually answer each post but thank you to everyone trying to help. No mice or rodents for sure. I will check out all other suggestions
    81 TOY likes this.
  14. Aug 7, 2021 at 4:24 AM
    Adam New Member
    AIP bypass or battery needs replaced. Also, we gotta see pictures of this truck!
