2007 stars then dies
Discussion in '2nd Gen Tundras (2007-2013)' started by MEWaters, Dec 22, 2024.
  1. Dec 22, 2024 at 7:00 AM
    MEWaters
    MEWaters [OP] New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    07 2UZFE
    218k
    Cranks and starts no problem and dies after a few seconds.
    Sitting at 1/4 tank fuel.
    No codes. No pending codes.
    Battery is good.
    Where do I start? Check fuses and relays?
    Was running fine yesterday when parked
  2. Dec 22, 2024 at 7:38 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    This type of deal used to almost always be a fuel problem (dead/dying fuel pump etc).
    A bad MAF(mass airflow sensor) would 100% cause your problem. However, you typically would get a code but I’ve seen them fail without the code right away.
    Id start with fuses (anything related to fuel delivery), check pump wiring/grounding - rodents may be chewing on them, then move on to the MAF.
    MAF sensor itself will have a couple fine wires that go into the air intake tube. If any are broken, thats your problem.
  3. Dec 22, 2024 at 7:46 AM
    15whtrd
    15whtrd Mr. Blonde
    If you think it’s the MAF, unplug it it will go into a default fuel mixture mode, but it will run. It’ll run like shit and get bad gas mileage, but it will tell you if it’s the MAF.
  4. Dec 22, 2024 at 8:40 AM
    MEWaters
    Maine
    MAF was cleaned 5k ago. Still good.
    Throttle body cleaned at same time.
    No apparent rodent problems but will continue looking around
