2007 Navigation Question - USB?
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Dec 20, 2016.
  1. Dec 20, 2016 at 5:28 PM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Just got this truck, it has an AUX for headphone jack cable but no USB.
    Question: Is there an available USB in the back of the radio I can tap into?
  2. Dec 20, 2016 at 5:58 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    No there isn't are you wanting to use USB to play music, or just charge your device(s)?
    The 2010+ do have USB, but as I understand it they have a different wiring harness so unless you have more money than sense, "upgrading" wouldn't be a viable option.
  3. Dec 20, 2016 at 6:31 PM
    Nor7
    wanting to play music. I am using a stereo 'headphone' cable right now, apparently the 2007 2008 won't stream music over bluetooth
  4. Dec 20, 2016 at 6:32 PM
    Nor7
    I can't complain too much, it does have 5 disc CD changer
    NewImprovedRon likes this.
  5. Dec 20, 2016 at 6:49 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
  6. Dec 20, 2016 at 6:52 PM
    Nor7
  7. Dec 20, 2016 at 8:04 PM
  8. Dec 21, 2016 at 8:35 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    There was on my basic stock radio. are you sure you can't use a cable to plug in the aux port to play music? That's usually what they are for. That box on Amazon looks good, but you might try a 5 dollar aux cord and see if it works first.
  9. Dec 21, 2016 at 6:04 PM
    Nor7
    Yeah I have an AUX connection and I'm using a cable that I have, I was just wanting a bluetooth connection to stream music over. It does phone calls. The problem right now is that if I charge the phone when its plugged into AUX I get some static.
