2007-2013 Tundra 5.7L (RCSB) Reg Cab Short Bed Production Numbers 4X2,4X4
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeff_5_7, Aug 19, 2022.
  1. Aug 19, 2022 at 7:00 PM
    Jeff_5_7
    Jeff_5_7 [OP] New Member
    Jeff
    Houston Tx Area
    Being a huge fan of RCSB (Regular Cab Short Bed) Tundras, I have been thinking for a while of a way to determine a close estimate at actual production numbers from Toyota. Everyone always wants to have the rarest of the rare when it comes to vehicles but how can it be "rare" if you don't know how many exist in the world. After several weeks and a lot of thinking I have come up with a clever solution.
    We all know each vehicle has a VIN (Vehicle Identification Number) to uniquely mark and identify each. I knew that if I could get a list of Tundra VINs I could sort them to see specifics for each year, body style, ect and a total count of valid VINs would give production numbers. However no such database of VINs just on the internet exist.
    So I reverse engineered all the VINs for RCSB Tundra's both 4X2 and 4X4. I only focused on 2007-2013 trucks with the 5.7L V8. The image below is a quick overview of the format and decoding of a VIN.
    Knowing the last 6 of the VIN are the unique serial number, I just assumed every serial number 000000-999999 was a RCSB Tundra and created a VIN to represent each if it was a 4X2 and 4X4. Now I had a huge list of engineered VINs that contained all real existing trucks and then some. To validate the data and remove "fake" VINs, I ran the entire database through an API to check each VINs record history. (Think running a CarFax only every VIN).
    I quickly found out serial numbers increment up uniformly which really helped (I had assumed this but you never know). This means I just had to establish the first and last valid serial number for each year model. Almost every valid serial number returned between 10-60 records associated with that VIN. These are records of oil changes, inspections, title changes, IE proof this is a real vehicle being driven in the world. VINs that returned 0 records are not valid and don't represent an actual truck that exist. I did find a handful of VINs with only 1 records which I assume is Toyota issuing a title and never selling them or something.
    Anyway here are the results. You will see in 2010 Toyota quit making 4X2 5.7L trucks. Overall many more 4x4 trucks made than 4X2. Still a pretty limited amount compared to all Tundra body's/styles.
    Just some cool info I thought I would share for those interested. I am not 100% guaranteeing these numbers are exact, but they are close and will give a good idea. All you regular cab 5.7 guys post your VIN here or at least check to make sure it falls in the right range. I have checked several trucks posted online for sale and every VIN lines up with my table so far.
    My truck is #001246 4X4 so I think that makes it the 113th one produced of the 5,063
    Side note: this was not easy to pull off, I don't think it would be possible to create and filter a database for double cab or crewmax Tundra's as it would be much much larger.
    M14 EBR, Eddy20, redrdr67 and 10 others like this.
  2. Aug 19, 2022 at 7:09 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Very cool as usual! Great work!
  3. Aug 20, 2022 at 7:00 PM
    e30cabrio
  4. Aug 20, 2022 at 7:36 PM
    Jeff_5_7
    Jeff
    Houston Tx Area
    e30cabrio[QUOTED] likes this.
  5. Aug 21, 2022 at 7:39 AM
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Here's mine. Seems to align;
    5TFJV52198X003006
    Jeff_5_7[OP] likes this.
  6. Aug 21, 2022 at 9:34 AM
    Richie Rich
    Richie Rich New Member
    California
    07 Crewmax Limited TRDOR.
    Coilovers, wheels, 35s, Amp steps, Carplay
    That is really cool.
    In addition to my Tundra, I also own a Tacoma X-Runner. It is another limited production truck that Toyota is pretty tight lipped about in terms of sales numbers.
    The common thought is that they made 3000 a year from 05 to 12 with limited (unknown amount) production in 12-13 for Hawaii and Puerto Rico. I have access to consumer auto data (wife's business is data) and found a total of only 3,100 unique records for the model designation.
  7. Sep 7, 2022 at 2:54 PM
    e30cabrio
    Here's another vin
  8. Nov 18, 2022 at 6:30 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine fits:
    5TFKY5F12BX004804
    Great post! Thanks for sharing your work.
  9. Nov 18, 2022 at 7:24 PM
    realest5.7
    realest5.7 New Member
    Cascadia
    2012 RCSB SR5 4x4 5.7 TRD Off Road
    Is there any way to confirm how many of the 5063 2007-13 RCSB 4x4’s were ordered with the TRD Off Road package ?
  10. Nov 18, 2022 at 7:27 PM
    Jeff_5_7
    Jeff
    Houston Tx Area
    Unfortunately no, the Vin only declares the trim level of which all regular cabs are basically the same. It doesn’t go into depth listing which packages were installed.
    The only way to check that it to run each vin through the Toyota Vin decoder to see add on packages. Last I checked Toyota doesn’t allow batch decoding so it would have to be done one Vin at a time.
    realest5.7[QUOTED] likes this.
  11. Nov 25, 2022 at 1:55 PM
    BRX
    BRX New Member
    Abdulla
    #1178 here with a 4X2, I guess that makes it the 56th RCSB.
  12. Dec 8, 2022 at 4:27 PM
    redrdr67
    redrdr67 New Member
    2007 White Tundra RCSB 2wd
    Thanks for doing this. Thought my 07 RCSB 2wd 5.7 was rare.
    M14 EBR likes this.
  13. Sep 9, 2025 at 10:45 PM
    Eddy20
    Eddy20 New Member
    I have been looking for an RCSB for 5 years 4X4 only. Thanks for the data I knew they were rare but with only a bit over 5,000 sold. And all these years later how many have been totaled or scrapped that's why they are very hard to find a rust free one. Also my friend a Toyota tech for almost 40 years, said he has never even seen one. But I think they mostly sold to the middle and east coast buyers (my guess). If they sold to the rust belt areas how many really are still on the road I wonder.
  14. Mar 1, 2026 at 4:24 PM
    427Tundra
    427Tundra New Member
    Ed
    2007 RCSB 2WD
    I just bought a blue 2007 RCSB 2WD Tundra with only 78,000 miles on it. It happened to be a local truck on Bring a Trailer. VIN is 5TFJV52167X001762.
    Treemite and Wynnded like this.
  15. Mar 2, 2026 at 3:18 PM
    Treemite
    Treemite New Member
    AZ
    Nice, let’s see some pictures! I’ve had several Tundras and the RCSB is my favorite to drive by far.
  16. Mar 2, 2026 at 3:29 PM
    M14 EBR
    M14 EBR Team Precision
    USA
    RWD 5.7L RCSB are the rarest.
  17. Mar 2, 2026 at 10:32 PM
    Hwy1rush
    Hwy1rush New Member
    Spenc
    07 RCSB SR5 TRD Off Road 4x4
    Lift
    Hi everybody I am new to Tundras.com. I always knew my truck was rare but this article is very helpful thank you. I have a 07 RCSB 5.7 L SR5 TRD OFF ROAD 4x4. VIN matches 001979.
