2007-2013 Toyota Tundra XB LED Headlights
Discussion in 'Lighting' started by Headlight Revolution, Sep 19, 2019.
  1. May 22, 2020 at 6:51 PM
    #691
    My passenger side was a foot low so I had to bring it up. I didnt set the dial at 0 though. I just adjusted it to where the drivers side was.
    TJMoeller[QUOTED] likes this.
  2. May 22, 2020 at 6:54 PM
    #692
    jwatt
    jwatt I heart men
    Jack
    Oregon
  3. May 22, 2020 at 6:58 PM
    #693
    TJMoeller
    TJMoeller New Member
    Timothy
    Bel Air, Harford Co. MD
    2007 NBM Crewmax Limited
    K&N drop in, TRD Dual exhaust, TRD stubby antenna, Morimoto XB LED headlights XB LED foglights & SpyderTaillights, Toytec 2.5/1 lift, FN BFD 18x9 +18 in Matte Bronze
    Correct, I used a Phillip's to turn from the top vertically, however I did not like how it was biting the gears so I switched to a 1/4" driver and adjusted from a horizontal position behind the headlight and that's when I saw a positive adjustment it took me 6-7 turns horizontally from the rear of the fixture to bring it back into alignment.
  4. May 22, 2020 at 7:01 PM
    #694
    TheBeast The Beach
    we gonna need some front shots :)
  5. May 22, 2020 at 7:02 PM
    #695
    Yeah it makes me wonder why it said no more than 3 turns or it would cause the aiming system to fail.
  6. May 22, 2020 at 7:10 PM
    #696
    TJMoeller
    Timothy
    I gotta say if anyone is on the fence about these, dive in and purchase them. I was for a while I upgraded the stock halogens to sylvania ZXE in the Spyder headlights and then I bought these and its like driving a metro prism and upgrading to a konigsegg. They are a tough cost to justify but once you fire them up you will not look back. Crispness, color, sharpness, immediate full brightness they are amazing. Combine them with the foglights and fuhhgetaboudit.!
  7. May 22, 2020 at 7:14 PM
    #697
    TJMoeller
    Timothy
  8. May 22, 2020 at 7:17 PM
    #698
    The picture of the fence is the DRLs by themselves. They are still decently bright when the headlights are on.
  9. May 22, 2020 at 7:20 PM
    #699
    TheBeast The Beach
    I would get the matching XB fog lights. I have been running them for 2 years and no issues. perfect match to the headlights. they are $200 ish sometimes less
  10. May 22, 2020 at 7:20 PM
    #700
    Lol. I just did a full Toytec lift 2 weeks ago and then these. The question of cost wasnt asked. :D
  11. May 22, 2020 at 7:23 PM
    #701
    TJMoeller
    Timothy
    I opted for the fogs when I bought the headlights they are great paired together for sure!
    TheBeast[QUOTED] likes this.
  12. May 22, 2020 at 7:27 PM
    #702
    TJMoeller
    Timothy
    I agree what you're saying, my wife is all about my passion of vehicles I wasnt even looking for a truck when I found mine. And the concern of cost when modifying directly results in more money down the line for cut corners is a big no bueno! I just have big plans and dont need to. Burn out the leeway quite yet!
  13. May 22, 2020 at 7:30 PM
    #703
    So based on the link that I found, I removed the motor from the OEM light. It will go in if you rotate it, but it will hang differently on the housing so it may or may not affect installing the light on the truck. There is also a small pin that sits in a slot when the motor is locked in, and you wouldn't have that if its rotated.
  14. May 22, 2020 at 11:06 PM
    #704
    CaliBPGen2
    CaliBPGen2 Dude
    Brandon
    Crazy-Cali
    2013 Silver Tundra
    Bed Cover, Liner, 2018 Tundra Wheels, Remote Start, Morimoto XB Headlights inbound. Just getting started...
    To account for the leveling issue, we should be able to cycle the dial to 5 and install the lights. Then turn the dial down instead of up when towing correct? Not a big issue to me if so.
    On my current install, I notice my lights adjust up when I turn the dial up. I have a sneaking suspicion the XB issue will offset the wiring issue I am dealing with and help right the wrong in play with my OEM light setup.
    Sadly, my new XB lights don’t come until next Tuesday. Let me know how the installs go .
  15. May 23, 2020 at 5:10 AM
    #705
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    Supercharger, Corsa, 5100’s
    Took them on a night run last night, not too bad. The drl’s are insane bright, the sequential signals and lock/unlock is pretty sweet. I need to find the adjustment sweet spot as currently I feel like I have to spots in the center, but I’ll get it with some time near a wall and some level ground.
  16. May 23, 2020 at 6:00 AM
    #706
    Yes if you are not lifted at all. I'm lifted so 5 is way too high. I was normally at 3.5 but now that its backwards I'll probably be around 1.5.
  17. May 24, 2020 at 6:36 AM
    #707
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    I installed the lights this morning. But for the life of me I can not get passenger side Hi-Beam connector to seat far enough to lock in place and it keeps falling out. So no hi-beam on side yet. :mad:
  18. May 24, 2020 at 7:55 AM
    #708
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    I had trouble with one of the connectors also. Just play with the pins slightly to move them until the connector slips on. Don't force it. Move a connector slightly and try it, repeat until it works.
    TheBeast likes this.
  19. May 24, 2020 at 9:01 AM
    #709
    radon222
    Ed
    NW Arkansas
    Stock for now
    Thanks for the suggestion. I'll fiddle with it more this afternoon.
  20. May 24, 2020 at 11:23 AM
    #710
    radon222
    Ed
    NW Arkansas
    Stock for now
    Final result: Everything is working! While fiddling around, I discovered the connector had no trouble going on upside down. So I de-pinned it, swapped the red & black wires and walla!
  21. May 24, 2020 at 11:27 AM
    #711
    How is your gap fitment around the lights? My drivers side fit a little better than the passenger side. I have to order new nylon inserts and then do some minor adjusting....damn OCD. At this point, I give up on the motors being backwards for now. I haven't even done a night drive yet.
  22. May 24, 2020 at 11:28 AM
    #712
    Nice. Those DRL are bright aren't they? Now figure out how to reverse the motors...lol.
  23. May 24, 2020 at 11:43 AM
    #713
    TheBeast The Beach
    I would wait for morimoto to come up with a solution as not to void the warranty.
  24. May 24, 2020 at 11:45 AM
    #714
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    2010 SR5 & 2021 TRD Pro
    Hopefully it's a simple fix, because it'll cost them a lot of money to replace all those lights under warranty. :eek2:
  25. May 24, 2020 at 11:48 AM
    #715
    A reverse worm gear would be the easiest most likely. They are made in Taiwan so it could be a while. :notsure:
  26. May 24, 2020 at 11:49 AM
    #716
    radon222
    Ed
    NW Arkansas
    Stock for now
    My gaps are a lot like yours tighter on the driver's side and a bit bigger on the passenger side. Since I'm not lifted my level adjuster was set at Zero. So I spun the level adjuster up to 5 before installation and I'll work it backwards if I need it.
  27. May 24, 2020 at 2:09 PM
    #717
    If I come up with some descent gap adjustments I'll let you know.
  28. May 24, 2020 at 2:51 PM
    #718
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    Did you guys try adjusting actual body panels?
  29. May 24, 2020 at 4:22 PM
    #719
    jwatt
    jwatt I heart men
    Jack
    Oregon
    At first I wasn t going to bring this up, but I m curious. Maybe someone has an opinion on the Vision X 07-11 TOYOTA TUNDRA FOG LIGHT KIT WITH XIL-UMX4010. It s here: https://headlightrevolution.com/vision-x-07-11-toyota-tundra-fog-light-kit-with-xil-umx4010/
    It uses the XIL-UMX4010 4" round Vision X Utility light @ 5 watts. Here s one here: https://puretundra.com/utility-market-xtreme-c-351_14_63_144/4-round-utility-market-xtreme-black-7-5w-leds-10ç-narrow-p-1674.html
    Headlight Revolution sells the brackets for the same fog light kit here: https://headlightrevolution.com/rep...lity-market-xtreme-led-fog-light-upgrade-kit/
    So theoretically I can buy the lights and brackets separately, and save $200.00.
    Is there something else, beside maybe a pigtail or something, that warrants an almost $200.00 markup?
  30. May 24, 2020 at 6:15 PM
    #720
    No I didn't. Its mainly where it meets the fenders.
