2007-2013 Toyota Tundra XB LED Headlights
Discussion in 'Lighting' started by Headlight Revolution, Sep 19, 2019.
  1. May 22, 2020 at 10:10 AM
    #661
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    2010 SR5 & 2021 TRD Pro
    I see great minds think alike. :rofl:I have a meter at home. Let's do it. :)
  2. May 22, 2020 at 10:36 AM
    #662
    Toyotango
    Toyotango New Member
  3. May 22, 2020 at 10:39 AM
    #663
    Arenbi
    Arenbi New Member
    Is the 20% off group buy coupon still going on today? I tried to use it but it said the code was invalid.
  4. May 22, 2020 at 10:46 AM
    #664
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    Go to the top of page 22, contact HR, and see if they can help you.
  5. May 22, 2020 at 10:53 AM
    #665
    ckkone
    ckkone New Member
    SLC, UT
    They are a great option Alpharex housings and lens with a 3rd party LED reflector, still carry a 2 year warranty from Alpharex. You can find them on eBay for $100 less than protunings website. I wanted to love the Morimoto but they are just too much money for what they are and I personally don't like a DRL that bright, kind of annoying reminds me of a Dodge.
    https://www.tundras.com/threads/new-led-headlights-tundra-pro-style.61059/
    See my email below from Alpharex.
    Alondra
    (AlphaRex)
    Apr 7, 10:49 PDT
    Dear Chris
    Hello yes they are and they come with a two year replacement warranty.
    Thank you.
    Apr 7, 10:24 PDT
    Subject: Full LED 2nd Gen Tundra lights on eBay
    Hi,
    Are these lights Alpharex? The lens in some pictures has your name on it. Anyway I'm just wondering if they are yours what is the warranty?
  6. May 22, 2020 at 11:04 AM
    #666
    Toyotango
    Awesome, thanks for the info. Looks like an eBay purchase is coming...I agree on all points. Morimoto seems overpriced for similar quality (fit & finish issues too from recent responses). Realistically, a fair price for the Morimotos should be $400-500 max. The rest must be marketing and profit based on the other options. All things considered, OEM or a proper retrofit is prob the best route in the end for quality & performance.
    driven1 and ckkone[QUOTED] like this.
  7. May 22, 2020 at 11:13 AM
    #667
    I was trying that. What I did was solder wires onto the old OEM headlight. Then I drilled out the connector portion of the motor cover and slide it over the wires and put it back on the motor since it wont move without the gear. I slid the other end of the wires into the connector the normal way to make sure I was getting power and it was working. When I tried a combo of swapping them around I didn't get anything to work. After a couple of tries it got hot outside lol. There are only 3 wires on the connector, and there is a dozen or so on the back of the dial switch. I just pulled it out enough to glance at it.
    TheBeast likes this.
  8. May 22, 2020 at 11:15 AM
    #668
    I just posted what I tried. Let me know if you have luck.
  9. May 22, 2020 at 12:35 PM
    #669
    I reached out to one of the wiring gurus to see if he has any inputs on the wiring for reversing the motors and also the dimming of the DRL in parking mode. I'll let you know what I find out. :fingerscrossed:
    TheBeast and copmagnet82 like this.
  10. May 22, 2020 at 2:43 PM
    #670
    TheBeast The Beach
    same here for the motors. inverted vs oem and when going up on switch it goes down on light. I'm always around 3 usually
  11. May 22, 2020 at 3:15 PM
    #671
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    Since my lights are not installed, yet, I want to clarify something and double check my understanding. Are the lights pointing towards the sky when adjusting with the dial, or are the lights still pointing down, but the numbers on the dial are reversed?
  12. May 22, 2020 at 3:20 PM
    #672
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    If you have a weight in the back of the truck, the front will point up. The level adjuster is supposed to rotate the lights down to correct for that. Increasing the number on the dial should be more downward rotation.
  13. May 22, 2020 at 3:26 PM
    #673
    O means that the lights are aimed down. When you turn the dial towards 5, the aim should go lower. The motors on the XB's are mounted 180 degrees different than OEM, so it causes the lights to go up when you turn the dial towards 5 instead of down.
    copmagnet82[QUOTED] likes this.
  14. May 22, 2020 at 3:31 PM
    #674
    I messaged Ihacker to see if he can provide any assistance with the motors and the DRL in parking light mode. He made the harness for the sequoia conversion so maybe it will be a starting point.
  15. May 22, 2020 at 3:42 PM
    #675
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    I get that. My question was if the functionality is the same with simply the numbers being reversed on the adjuster. If that was the case, as long as the lights are rotating down, I wouldn't care if the lowest position was at 1 or 5.
  16. May 22, 2020 at 3:46 PM
    #676
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    :thumbsup: This seems like is should be a simple fix, either with polarity reversal or possibly opposite worm gear...:notsure:
  17. May 22, 2020 at 3:47 PM
    #677
    Yes they still work, just backwards. I think the only concern would be limited adjustment if you tow heavy loads.
  18. May 22, 2020 at 3:54 PM
    #678
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    I wonder if everyone has the issue with leveling motors running backwards, or is it only some of us???
    I'm also wondering if there is a way to max out the headlights at the highest position with the motors, then aim them properly with adjustment screws, and from there, once they are maxed out at the highest position, they can only go down. Not sure if that's possible, just brainstorming.
  19. May 22, 2020 at 4:05 PM
    #679
    TheBeast The Beach
    I think we all have them. motor still works, just the opposite. I think most of us don't really look at the dial and adjust looking at the light in front of us. That's why I did not pay attention at the feature but you guys got me curious :)
  20. May 22, 2020 at 4:16 PM
    #680
    Which screw is the low beam adjustment? Passenger side is lower than the drivers side.
    Edit...the low beam adjustment is the one on the motor itself. My passenger side was way low.
  21. May 22, 2020 at 5:11 PM
    #681
    So it looks like we are stuck wiring wise for the motors. Below is his reply.
    Hello sir,
    I see you guys are having this weird thing in the second gen Morimoto headlights, unfortunately for the moment don’t have any information about this headlights but let me tell you that the only way to do it is modifying the motors, flipping wires don’t have Any effect on this issue.
    Your best bet is keeping in contact with the manufacturer to see if they figure out and send you a tweaked motor module.
    If I hear about a solution for this I’ll contact you
  22. May 22, 2020 at 5:15 PM
    #682
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    We are already on a second gen Morimoto headlights??? I wonder if we should all just call Morimoto, so they can get to work on fixing this. :smack:
  23. May 22, 2020 at 5:16 PM
    #683
    TheBeast The Beach
    can the motors be inverted on the morimotos ? can we flip them upside down ? they look the same as oem.
    the plot thickens :)
  24. May 22, 2020 at 5:22 PM
    #684
    I already posted their reply. They said they addressed it with the manufacturer.
  25. May 22, 2020 at 5:24 PM
    #685
    I dont even know how you remove them from the lights. As I posted the earlier pictures, you can see how they are opposite.
  26. May 22, 2020 at 5:55 PM
    #686
    Does the sticker really mean no more than 3 turns? I had to turn quite a few times for adjustment.
  27. May 22, 2020 at 6:11 PM
    #687
    TJMoeller
    TJMoeller New Member
    Timothy
    Bel Air, Harford Co. MD
    2007 NBM Crewmax Limited
    K&N drop in, TRD Dual exhaust, TRD stubby antenna, Morimoto XB LED headlights XB LED foglights & SpyderTaillights, Toytec 2.5/1 lift, FN BFD 18x9 +18 in Matte Bronze
    My passenger side was the same way, ultimately I did rotate more then suggested to get back into alignment and I havent had an issue since. I fought and fought with myself and I totally did lol!
  28. May 22, 2020 at 6:13 PM
    #688
    That's good to know bc I definitely went more than 3 turns. Do your motors run backwards too?
  29. May 22, 2020 at 6:26 PM
    #689
    TJMoeller
    Timothy
    Mine being an early model 07 I do not have the leveling option from factory. My passenger side took like 6-7 turns to bring it down into range from 25' away
    -- I just turned the screw very slowly while clinching the b-hole hoping nothing would happen lol
  30. May 22, 2020 at 6:48 PM
    #690
    So i just went out and adjusted it. If you use the screwdriver from the top to turn the gear teeth, then you would have to turn the screwdriver quite a bit to exceed 3 turns. If you turn it from the nut on the back side, it seems like you exceed the 3 turns. Does that make sense at all? After the adjustment they both worked fine up and down with the cab adjustment. Holy @#$% the DRLs are bright by themselves. The color of the low beams matches my Rigid fog lights perfectly.
    tnbndr, Jfuggint and TheBeast like this.
