2006 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Browntundra123, Jan 10, 2021.
  1. Jan 10, 2021 at 7:33 PM
    Browntundra123
    Browntundra123 [OP] New Member
    So when I got my truck the regular halogen fog lights works, now I had switch to LED bulbs for the fogs and it won't work, tried switching back to halogen now this won't work,,, not sure whats going on but now when I turn on the fog light from the factory switch, the high beams come on. Now I checked all the fuses. There's power it all. But when I checked for power at the fog light insert there is no power. Now I did check most of the wiring but before I start slicing or adding in more wires, I'd want it to work with the factory switch. Any suggestions what might be wrong?
    dropindeuces and Tundra2 like this.
  2. Jan 10, 2021 at 7:44 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You need headlight resistors in line with your leds.
    I have these. They are plug, and play. I used jbweld steelstik to mount them to my engine bay wall near the headlight. No drilling or screws.
    Some claim that you only need one resistor. I used both because I never saw a definitive "Yes" from others. They are cheap, but I've had mine two years now.
    sflips, dropindeuces and KNABORES like this.
  3. Jan 11, 2021 at 10:25 PM
    dropindeuces
    dropindeuces New Member
  4. Jan 12, 2021 at 3:55 AM
    Professional Hand Model
    Hand Protectors
    Seems the 2005-06 usually has troubles with LED bulbs.
    Sometimes its the brand. Sometimes its the year of truck. Sometimes its both. Call your bulb company and ask what is the remedy.
  5. Jan 12, 2021 at 7:30 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  6. Jan 13, 2021 at 4:19 PM
    HanD
    HanD New Member
    Maryland
    05 DC
    have you tried disconnecting the DRL module by the battery?
  7. Feb 2, 2021 at 10:33 PM
    dropindeuces
    Yup I got the LED's and that kit and when i powered up the resistor unit got hot as SR$*T in a few seconds. I tried a few others (I picked up four just in case). Screw it man, im going back to stock and just run external lights.
  8. Feb 2, 2021 at 10:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    for my truck the fix was rewiring the fog light switch to a ignition switched 12v instead of grabbing 12v off the headlight high beam... and in turn i also effectively did an fog light any time mod.. its nice when they stay on with the high beams now
    dropindeuces likes this.
  9. Feb 2, 2021 at 10:45 PM
    dropindeuces
    I think that actually might work. Im guessing you wired it to the ignition line due to the current draw because you wanted to take off the load off the other line?
  10. Feb 2, 2021 at 10:58 PM
    empty_lord
    05 rollover special
    I just used the unused fuse in the interior fuse block with a add a fuse and ran that to the stalk with a 5 amp fuse. All it’s doing is energising a coil for the relay. The reason I did this is because the fog lights are the reason we have issues with the leds or in my case, a high power headlight harness for running 100w halogen bulbs. A resistor is indeed a fix, but I didn’t want a resistor with my already larger load from the more powerful bulbs
  11. Feb 3, 2021 at 3:36 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  12. Feb 3, 2021 at 3:46 AM
    Hand Protectors
    SuperNova Bulbs in Fogs with Katanas in Headlight Assys work without all the need for messy wires and tricky dickie wiring in 2002 Models.
    abcinv likes this.
  13. Feb 4, 2021 at 7:47 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Superbright LEDs sells a CAN style LED head and fog light that doesn't require a resistor. It's what I run on my 06 SR5. The fog lights are polarity sensitive so if you install them and they don't work just rotate the harness.
