2006 Tundra rims fit T100
Discussion in '1st Gen Tundras (2000-2006)' started by abcinv, Mar 6, 2020.
  1. Mar 6, 2020 at 2:24 AM
    abcinv
    abcinv [OP] OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I'm offering up my original rims to a guy at work who drives a T100, not sure of the year. Both being 6 lug I believe they'll match up but wasn't sure about other spacing issues he may run in to.
    Anyone have any experience with this setup?
    This is the rim style if it matters (ignore the cap I'm holding with my non-professional hand model pic) -
  2. Mar 6, 2020 at 12:54 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    should be fine.
  3. Mar 6, 2020 at 1:01 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4
    I can't see the pic, but the hub on the T100 stick out farther than our trucks, so on the front he may not be able to use the center cap
  4. Mar 6, 2020 at 1:52 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    What those guys said is right.
    I had a T100 before my Tundra and had a few different oem 6 lug wheels on it over the years, Tacoma and Tundra styles, the hub caps probably won’t fit right on the front, as mentioned, and if there are tires mounted they may rub depending on the size of tire. The last ones I had rubbed a little on the frame at full lock, and sometimes on the splash shields.
  5. Mar 6, 2020 at 2:04 PM
    Professional Hand Model
    Hand Protectors
    I have an idea. Instead of searching why don’t you just buy a T-100 and end your misery here?
    bmf4069 and jordan0317 like this.
