2006 Tundra needs more power
Discussion in 'Performance and Tuning' started by Ganakis, Jun 29, 2016.
  1. Jun 29, 2016 at 3:41 PM
    Ganakis
    Ganakis [OP] New Member
    Stock
    I'm considering 2 options for my 06 tundra. A 4.7l just doesn't seem enough so I would either like to swap for a 5.7 or turbo the 4.7, does anyone have suggestions or other ideas...
  2. Jun 29, 2016 at 5:06 PM
    5.7 S/C'd and tuned?
    zcarpenter92 and bandit like this.
  3. Jun 29, 2016 at 6:47 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    THIS
  4. Jun 29, 2016 at 8:34 PM
    Ganakis
    Stock
    What do you mean by tuned?
  5. Jun 29, 2016 at 9:16 PM
    Mike Tread lightly.
    south carolina
    4.7 is a beast if your pockets are deep enough...
    because_wumbo-truck likes this.
  6. Jun 30, 2016 at 6:23 AM
    Ganakis
    Stock
    Was thinking of a turbo and cam for the 4.7
  7. Jun 30, 2016 at 6:27 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
  8. Jun 30, 2016 at 6:47 AM
    Ganakis
    Stock
    Got to love the spell check on forums, cams and turbo ;) better?
  9. Jun 30, 2016 at 8:20 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Supercharge vs turbo charge, which is the better option???
  10. Jun 30, 2016 at 9:10 AM
    Ganakis
    Stock
    Depends on what you want out of it....supercharger is by belt and turbo by exhaust...if you want massive power twin turbo is where it's at
  11. Jun 30, 2016 at 11:13 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    A remote turbo would be sick, low boost and a good tune would probably run really well. I believe it's the connecting rods that are the weak link in our engine. Read that somewhere I think.... I think I'm gonna stick with intake, exhaust and headers for mine. It does what I need it to do. Hard to ask a 4.7 to perform like a 6.2
    BestGen likes this.
  12. Jun 30, 2016 at 11:52 AM
    Ganakis
    Stock
    Was thinking of rebuilding the block, has 200k miles and wanting to living up the truck and either replace with bigger or rebuild and add power...not sure which is the better option or best option
  13. Jun 30, 2016 at 12:02 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    This. 2UZ rods are cast. Running any kind of forced induction on them and poof. Babies in the oil pan.
    Short of doing a completely built engine, I wouldn't turbo it.
    BestGen, T-Rex266 and Ganakis[OP] like this.
  14. Jun 30, 2016 at 12:39 PM
    Ganakis
    Stock
    If I keep the 4.7 I was planning on rebuilding it regardless but still weighing options
  15. Jul 13, 2016 at 12:29 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    my low boost, high mileage, turbo set up works well for me:)
  16. Aug 19, 2018 at 10:31 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    What kinda yield does the typical 4.7 get from a a full exhaust with headers? Should you upgrade the intake too?
    Casper421 likes this.
  17. Aug 19, 2018 at 11:23 AM
    Casper421
    In the woods
    06 DC
    @dirtydeeds Have any numbers on gains from your 1st gen long tube headers and exhaust or your full race exhaust?
  18. Aug 19, 2018 at 1:30 PM
  19. Aug 19, 2018 at 4:55 PM
    dirtydeeds
    Keith
    USA
  20. Aug 19, 2018 at 6:05 PM
    Aron9000
    Aron9000 New Member
    Aaron
    Gonna be the hater here, and say GM LS swap with giant turbo.
    Depends on your power goals here though, 400whp should be doable with a newer Toyota 5.7 V8 with the blower, that combo should be reliable(it was offered with a factory warranty) provided you don't make a hack of the install and wiring. Might need the newer 6 speed automatic that came with the 5.7 V8, not sure if the current transmission(and rear end) are strong enough in your gen 1 Tundra.
    To swap a 5.7 into the gen I is going to be a lot of custom work, maybe just as much as putting in a GM LS engine. And reason I say GM LS, the aftermarket is HUGE, engines are cheap, parts are cheap, lots of expertise on tuning this engine. I mean you can make a 500+whp truck with the stock 5.3 block out of a late model Tahoe or Silverado, those engines are cheap(like $500 for a low mile runner) from a junkyard.
    It really is what do you want out of your truck. Reliable daily driver, I'd just upgrade to a newer Gen II Tundra with the 5.7 already under the hood.
  21. Aug 26, 2018 at 6:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I didn't want to be the guy who suggests putting a Chevy heart in a Toyota body, but what Aron says has been done several times and can give more bang for your buck.
  22. Aug 26, 2018 at 7:37 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Save yourself the headache and time. Do what I did and keep the 4.7. Invest in a newer tundra with the 5.7.
    Rex Kramer and Steve89gt like this.
  23. Dec 21, 2018 at 6:08 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Is it safe to assume that going from a 4 to 12 hole injector may result in MPG loss? Or am I wrong?
  24. Dec 21, 2018 at 6:24 AM
    15whtrd
    15whtrd Mr. Blonde
    I would think, probably not. It depends on where your foot is on the throttle LOL. It’s probably more efficient.
  25. Dec 21, 2018 at 6:26 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Possibly. I was just thinking if you're sucking in more fuel, and to gain more performance, you will use more. Last thing I need to is get even worse MPG LOL.
    Casper421 and 15whtrd[QUOTED] like this.
  26. Dec 21, 2018 at 6:29 AM
    Casper421
    In the woods
    06 DC
    15whtrd[QUOTED] likes this.
  27. Dec 21, 2018 at 6:40 AM
    Casper421
    In the woods
    06 DC
    I’ve been considering the injectors as well and had the same thought.
    15whtrd likes this.
  28. Dec 21, 2018 at 6:49 AM
    15whtrd
    15whtrd Mr. Blonde
    If it was carbureted (Double pumper) and you went bigger, I would say yes, worse fuel mileage.
    But fuel injection, is efficient and I would assume if you drive normally it may be the same mpg or possibly better? Maybe I’m just optimistic. I do tend to drink the koolaid...
    Casper421[QUOTED] and BestGen like this.
  29. Dec 21, 2018 at 6:59 AM
    Casper421
    In the woods
    06 DC
    Valid point and the ecu would probably learn and adapt to the new mixture. When was the last time you drove normally after adding a “performance upgrade”?
  30. Dec 21, 2018 at 7:05 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Somewhat related but I know people that have added cold air intakes to various vehicles and gotten worse MPG.
