2006 Tundra eats alternators
Discussion in '1st Gen Tundras (2000-2006)' started by mercman, May 13, 2022.
  1. May 13, 2022 at 3:20 PM
    mercman
    mercman [OP] New Member
    Last year my alternator was outputting about 9 VDC. I replaced it with a new alternator and installed a new drive belt, also.
    Now about a year later I again have low voltage and need to jump start it. Identical symptoms as last year.
    What's up?
  2. May 13, 2022 at 3:35 PM
    Aerindel
    Aerindel New Member
    Montana
    Battery.
    Battery Cables.
    des2mtn, BubbaW and KNABORES like this.
  3. May 13, 2022 at 3:40 PM
    shifty` Countin' and breathin', disappearin' in the fade
    Did you use OEM/Denso parts? The quality of 3rd party brands has seriously gone down the shitter in the last decade or two, and forget about reman units from those brands.
    Did you make the mistake of ordering your parts from scAmazon or fleaBay? They're well-known at this point for being a source of Bs counterfeit parts, it's rampant and no way to easily protect yourself.
    bmf4069, ColoradoTJ and HBTundra like this.
  4. May 13, 2022 at 3:46 PM
    I’ve noticed that rebuildable parts like brake calipers, alternators and starters have been of poor quality lately. As in, bad out of the box, no QC. Which sucks when your chasing a problem and think you’ve eliminated a cause and are working down the list. I second the battery cables and ground points. Big 3 upgrade. Highly recommend.
    shifty` likes this.
  5. May 13, 2022 at 5:54 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I had a bad battery cable at about 240k. Was corroded inside the wire casing.
    When I got the truck it had an autolite reman alternator. It went out around 260k.
    I bought a reman denso from a local mom and pop store for $200. Toyota only sells remans and they were $450.
    Denso has been working perfect. Solid 14v all the time.
    HBTundra and des2mtn like this.
  6. May 13, 2022 at 8:52 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    You're talking about the alternator, or the starter? ;)
    I just put over 2000 miles on a Denso reman from RockAuto. 14v+ whenever the engine is running; pretty sure it will hold up.
    FrenchToasty and HBTundra like this.
  7. May 14, 2022 at 5:26 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Where are you measuring voltage? (At the battery terminals? At the alternator positive post?)
