2006 Tundra Double Cab Amp Bypass?
Discussion in 'Audio & Video' started by PISTOL393, Oct 23, 2020.
  1. Oct 23, 2020 at 8:16 AM
    PISTOL393
    PISTOL393 [OP] New Member
    2006 Tundra SR5 Double Cab
    I am installing a new HU, amp, & speakers. I will be running new wire to the speakers. Do I have to bypass the JBL amp?
  2. Oct 23, 2020 at 12:01 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I removed and bypassed the amp in my 06 DC Limited. The factory amp was six channels and the aftermarket headunit and amp is most likely a 4 channel setup.
  3. Oct 23, 2020 at 12:12 PM
    PISTOL393
    So even if I’m running 4 channels (2-ways in the rear doors & components in the front doors) & run new wiring for them I still have to bypass the amp? If yes, please explain.
    Thanks!
  4. Oct 23, 2020 at 12:44 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    You're effectively bypassing the amp by running new speaker wires, so if you mean can you leave the amp alone, then yes.
    Just curious, what speakers and head unit are you going with?
  5. Oct 23, 2020 at 3:44 PM
    PISTOL393
  6. Oct 26, 2020 at 9:03 AM
    rock climber
  7. Oct 26, 2020 at 9:14 AM
    Elduder
    Elduder New Member
    This. I had installed a Kenwood HU on my Pro, ran RCAs from the HU to the amp for the front speakers only, then wires back to the cross overs and speakers. Retained the stock rear speakers without changing anything to them.
  8. Nov 21, 2020 at 6:03 PM
    MelissaWilliams
    MelissaWilliams New Member
    Melissa
    I am having so much trouble. New to this radio thing. I'm trying to bypass the jbl amp for the stock one how do I find it?
  9. Nov 23, 2020 at 7:56 AM
    rock climber
    What year and cab configuration?
