2006 Toyota Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Myssabar, Oct 19, 2021.
  1. Oct 19, 2021 at 11:05 PM
    Myssabar
    Myssabar [OP] New Member
    Edward
    2006 Toyota Tundra
    Just bought a 2006 Toyota Tundra Double Cab Limited. My very first truck.
    First of all did I pay too much? 11k and has 177k miles. Person who owned it was a mechanic at Mercedes Benz. I cant ask him any question because he passed.
    Secondly what things should i replace first? Spark Plugs and all the fluids?
    Also any advice for me would be good.
    Thanks in advance
  2. Oct 19, 2021 at 11:27 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  3. Oct 19, 2021 at 11:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Depends on the condition of the frame. Depends on when the last TB/WP was.
    Myssabar[OP] and 1lowlife like this.
  4. Oct 20, 2021 at 3:02 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats and welcome from Gettysburg... Nice1st gen Rig
    Myssabar[OP] likes this.
  5. Oct 20, 2021 at 5:28 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    Welcome aboard,, nice looking truck (from the picture),, looks clean. Good job!!:)
  6. Oct 20, 2021 at 5:54 AM
    shifty` One great big festering neon distraction
    If the timing belt looks good and the frame isn't in bad shape, I think you did OK on pricing.
    First thing you should check is any maintenance records, before you attempt any maintenance. You may find some by signing up at Toyota's site - go here and click the JOIN NOW button to add your truck and review any dealership service records: https://www.toyota.com/owners/my-vehicle/vehicle-specification. You may also want to confirm in there whether there are any open/unfinished recalls, like on the airbags.
    If there are no records regarding the last timing belt change, because the owner was a mechanic and may've done it himself, look in the engine bay for a timing belt change sticker, often people will put it on the air intake tube, listing the last timing belt change. If there's no sticker, you can pull back the cover, take a CLEAR photo of the timing belt, and someone here can tell you if it's in need of change. If so, and you need a shop to do it, you're looking at $1200-1400. But it's not something you don't want to do, because if it snaps, you're looking at a new engine ($2k-4k). General rule of thumb is to try and replace your belt every 10yr/100k miles, although Toyota's recommendation is a bit shorter, I think 9yr/90k, some people have managed to go double that - I personally don't like to gamble.
    Other than that, be prepared for possible front suspension work. You may want to check a couple of plugs just to see whether they're healthy before you change them, if "iridium" they may 10s of thousands of miles of life remaining. Peace of mind is nice, but I'd check my fluids before changing anything with hopes that a mechanic would've taken tip-top shape of their vehicle... But I also know sometimes "the cobbler's kids have no shoes".
  7. Oct 20, 2021 at 6:03 AM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    Welcome from AZ
  8. Oct 20, 2021 at 7:37 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. Oct 20, 2021 at 10:57 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Looking at the photo, it appears that he's in California, which would certainly negate the frame concerns..
    X3 on the timing belt. I would assume since the previous owner was a wrencher, he probably took care of it, but you know what happens when you assume....
    bmf4069, 1lowlife and Myssabar[OP] like this.
  10. Oct 20, 2021 at 10:27 PM
    Myssabar
    Edward
    2006 Toyota Tundra
    Man good thing you brought up timing belt. I thought I had a chain. After research I see it has a chain. Just looked up a youtube video on how to check the belt. Seems pretty straight forward.
  11. Oct 20, 2021 at 10:28 PM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    Welcome aboard!
  12. Oct 20, 2021 at 10:28 PM
    Myssabar
    Edward
    2006 Toyota Tundra
    Good guess. How can you tell from looking from the photo you knew it was California? lol
  13. Oct 21, 2021 at 4:04 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    The Tile roof was the dead giveaway. Also, the car in the garage appears to have a Sunset plate..
    Basically just a good guess...
    Oh, and welcome to the club!
    des2mtn likes this.
  14. Oct 21, 2021 at 6:02 AM
    Yeah, that's the one elephant in the room that'll bite you in the ass. Interference engine, that belt snaps, bye-bye engine. The other thing to be aware of is pink milkshake. The way the OEM radiator is designed in these trucks, it's possible for certain models to have coolant mix with transmission fluid and vice-versa. Can cause shifting problems. If you're running an aftermarket radiator, or your truck has a separate transmission cooler, nothing to worry about.
    On the timing belt inspection, 2-3 minute process. You can either pop out a couple 10mm on the passenger side cover or driver side cover to check the belt. If it's still matte with no visible cracks, you're golden, keep checking every 10k/1yr. If it's mildly glossy, I'd consider that half-life-ish. If it's glossy glossy, you should start thinking about replacing, and if glossy with visible cracks, you're on borrowed time.
    Since we know you're in a sunny state, just a cosmetic warning. During the years of the 1st gen trucks, Toyota was only doing clearcoated paint jobs on the metallic trucks (base metallic coat + clear coat over it). Non-metallic trucks got a single stage (clear and color mixed, single coat). I personally suspect they may've have an issue with the clear they were using because clearcoat failure on the metallic trucks, especially the red/blue/green colors, was poor. Horizontal surfaces like the roof and hood tended to peel first, common spots being where the hood meets headlights, where the roof meets windshield, where the door meets the roof, and top of the fender flares. If you're not already bubbling and hazing in those spots, be sure to keep those areas well-waxed with a UV-blocking wax or coating. I have no reco for you on product, that's like bringing up guns, religion, and politics in one sentence at Thanksgiving family reunion.
  15. Oct 21, 2021 at 6:06 AM
    PS - you'll see a huge night driving experience increase if you replace your headlight housings, yours look like ass, no amount of sanding, polish and clearcoat will fix that. Removal is easy, there's a simple trick. Don't rely on YouTube videos for help on that, they'll tell you to pry out the blinker. Not necessary. Once you get the turn signal bolts out, just stand next to your front tire and gently 'palm slap' the blinker housing forward. The rest is cake. Long phillips head screwdriver to adjust level after it's all bolted in using the provided adjustment hole.
  16. Oct 21, 2021 at 6:51 PM
    Myssabar
    Edward
    2006 Toyota Tundra
    Dont want to start any arguments if it anything like the Harley Davidson forums. But what Spark Plugs and Oil Filter do you guys recommend. I left out what type of oil because that usually starts the long argument lol But I will be going full synthetic.
  17. Oct 21, 2021 at 7:16 PM
    OEM filters for air & oil are king. It's one thing Toyota crushes the other manuf'ers on. Convinced it's part of the reason their drivetrains last so long. Inexpensive, effective.
    Most people I see are plugging iridium plugs here, but don't buy on fleabay / amazoan, counterfeit-central. Buy from a trustworthy source.
    Oil, most people are on the Mobil1 wagon here from what I've seen. Coolant: Toyota red.
    bmf4069 likes this.
  18. Oct 22, 2021 at 12:39 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Oil filter PN for OEM is 90915-YZZD3 (if the later 4.7s are the same as the early)
    bmf4069 likes this.
  19. Oct 22, 2021 at 9:54 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I had been buying my OEM oil filters from Walmart, but they upped the price to $7 and I found out if I order online from my dealership they are $4.
    For spark plugs either denso or NGK, just don't buy from Amazon. NGK has two different iridium plugs, one is a 30,000 mile and the other is 70,000 (I think)
    Myssabar[QUOTED][OP] likes this.
  20. Oct 26, 2021 at 8:23 PM
    Myssabar
    Edward
    2006 Toyota Tundra
    Do you guys use OEM shocks? I dont plan to go off roading i just use to drive around town. Any cheaper route that any went and was happy? Also, what kind of stereo and speakers did you guys upgrade to? I miss having Bluetooth to steam my music or take calls.
    Konniekay91 likes this.
  21. Oct 26, 2021 at 8:37 PM
    des2mtn
    Tonto cover
    Lots of people use Bilstein shocks for what you're looking to do. Either the 4600 or 5100 series. You can re-use your stock coils with them, I would start looking into those. I don't have first-hand experience with the Bilsteins, but there are plenty of 1st Gens on here that like them for street applications.
  22. Oct 26, 2021 at 9:34 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    I recommend the Bilstein 4600, or KYB gas A just, KYB’s are cheaper and they are great too.
  23. Oct 27, 2021 at 6:44 AM
    Durbin7
    Durbin7 New Member
    Ohio
    Welcome, I have an 06 and it has been a great truck, hope you enjoy yours.
    Konniekay91 and Myssabar[OP] like this.
  24. Dec 16, 2021 at 10:24 PM
    Konniekay91
    Konniekay91 New Member
    Konrad
    2006 Toyota Tundra SR5 Doublecab
    I'm torn between the Billy 4600 and 5100. 4600 because Im not running anything super oversized (P265/70r17) and don't tow heavy loads, mostly other tires and smaller equipment. Plus it's only a Gen 1 DC 2wd so I don't see a lot of off roading, just typical unmaintained dirt road.
    5100 because I might change my mind and if I could lessen the rake just by an inch or inch and a half, it's well worth it.
    Only concern is ride quality on the 5100, that's the only thing that's keeping me from going all in.
  25. Dec 16, 2021 at 10:49 PM
    Konniekay91
    Konrad
    Also, welcome from AZ!
  26. Dec 17, 2021 at 6:32 AM
    Plan to lift or level? Go 5100. Just need an OEM+ upgrade or replacement? Go 4600 and save yourself some coin.
  27. Dec 17, 2021 at 10:47 AM
    rock climber
    I've heard no complaints on the ride quality of the 5100, especially when compared to the 4600.
    Konniekay91[QUOTED] likes this.
  28. Dec 17, 2021 at 10:49 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    In today's market with those miles you did good.
    25mike and Konniekay91 like this.
