2006 toyota tundra sr5 double cab
Discussion in 'New Member Introductions' started by Verlyn1954, Jun 26, 2020.
  1. Jun 26, 2020 at 9:49 AM
    Verlyn1954
    Verlyn1954 [OP] New Member
    I own first gen tundra,Great truck love the price because I own it,Hi to all vt..
    e3phung and Pinay like this.
  2. Jun 26, 2020 at 9:57 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal
  3. Jun 26, 2020 at 10:15 AM
    Verlyn1954
    Hi back, From So, Cal
    Im, hoping some one can help me with any ideas,in my 2006 toyota tundra sr5 double cab,I installed fog lights and added leds 9600 bulbs to factory harness, Also Upgraded Stalk with fog switch from toyota ,Had Toyota dealer ship install. Fog relay at back of cabin fuse box,Only thing that happens when I turn on fog light switch is it turns on high beam head lights only No fog lights, Also I have upgraded headlights to led bulbs as well if that matters,Any ideas , Thanks very much in advance,Vt
    YardBird likes this.
  4. Jun 26, 2020 at 10:16 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The PSW.
  5. Jun 26, 2020 at 10:17 AM
    Verlyn1954
    Thanks vt
  6. Jun 26, 2020 at 10:24 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  7. Jun 26, 2020 at 10:29 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    It's actually a fairly common problem, you need resistors. Post I found
    Hi Haze134,
    you need to buy a resistors for balance the loads in the circuit and can work the relay of the fog lights.
    You can find this on ebay for 15.95usd
    2x A10 EMC 9006 Headlight Kit Canbus LED Decoder Load Resistor Warning Canceller
    $19 2x A10 EMC 9006 Headlight Kit Canbus LED Decoder Load Resistor Warning Canceller
    https://www.ebay.com/itm/2x-A10-EMC...ash=item41b3109cb3:g:1bwAAOSwLnBX2dRL&vxp=mtr
    I hope this solve your problem my friend, i was the same problema few months ago with my powerful tundra 2000
  8. Jun 26, 2020 at 10:43 AM
    Verlyn1954
    Do these plug directly into Fog lights Thanks in advance,Vt
  9. Jun 26, 2020 at 11:25 AM
    Verlyn1954
    Thanks I will try this,Thanks for the help
    Vt
  10. Jun 26, 2020 at 11:37 AM
    Azblue
    The Dirty T ( ^_^)_且
    Are you saying that the fog light switch turns the high beams on or that the fog lights just don't work with the high beams but work fine with the lows? If it's the latter then that is perfectly normal. Factory fog lights only work with the low beams and shut off with the highs.
    There is a simple "Anytime Fog Lights" wire mod on the 2nd and 3rd Gens, don't know about the 1st Gens.
  11. Jun 26, 2020 at 11:42 AM
    Verlyn1954
    Fog light switch on Stalk on High beam head lights only, if I have head lights on low beam for instance, and I turn on fog switch it brings in high beam head lights only, nothing else
    Thanks in Advance, vt
