2006 timing belt replacement only 71500 miles????
Discussion in '1st Gen Tundras (2000-2006)' started by CatslaveNM, Aug 5, 2016.
  1. Aug 5, 2016 at 11:01 AM
    CatslaveNM
    CatslaveNM [OP] New Member
    2006 Tundra SR5 4WD Ext.cab
    none
    Manual says at 90000 miles but dealer saying at 9 years due to age...mine garage kept.
    Probably will not take risk of a break.....
    Any recos?
  2. Aug 5, 2016 at 12:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have never read anything relating to a timing belt needing to be replaced due to age. I call rubbish. I would be suspect of anything that particular dealer suggests. This is just my opinion, get others.
  3. Aug 5, 2016 at 1:30 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    It's not rubbish. Just like tires, belts have a lifespan based on age and mileage...whichever comes first.
    My parents (both were mechanics) always suggested replacing timing belt at 7 years.
    ColoradoTJ likes this.
  4. Aug 5, 2016 at 1:34 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I forgot whether the 4.7 is interference (I shouldn't, there's one on my 4R) but if it is, I'd never take the risk. It would be a shame to eff up that low mileage '06 engine by punting a valve through a piston.
    So my vote is to change...
    jberry813 likes this.
  5. Aug 5, 2016 at 1:42 PM
    jberry813
    Lake Tahoe
    The 2UZ is indeed an interference engine.
  6. Aug 5, 2016 at 1:50 PM
    tomsinamerica
    Tom
    Wilmington, NC
    That gets very Ouchy very quickly
  7. Aug 5, 2016 at 1:54 PM
    jberry813
    Lake Tahoe
    Yessir.
    I will say that Toyota is pretty intelligent with interference/non-interference and chain/belt. The vast majority of their interference engines are timing chains. The only one I can think of as the exception to this in the last 10 years is the 2UZ.
  8. Aug 5, 2016 at 2:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    LOL, I can't fault your analogy between the belt and tires. I suppose that if a person were accumulating between 12/15k miles a year, that would align with approximately the recommended mileage suggested for a T-belt replacement. I've never noticed it in print though. I suppose that if someone had asked if they should consider changing the T-belt on a 70k mile vehicle that hasn't been run for five years, I likely would've replied otherwise. But say the owner drove the vehicle only 500 miles a month, regularly; might that give you pause? Not to go off on too much of a tangent, the scenario is simply wandering around in my head.
  9. Aug 5, 2016 at 2:35 PM
    jberry813
    Lake Tahoe
    I'd still replace it. Rubber breaks down with age. Breaks down even faster if it comes in contact with oils or solvents.
  10. Aug 5, 2016 at 3:49 PM
    Mike Tread lightly.
    south carolina
    X2...
  11. Aug 18, 2016 at 9:04 PM
    Scarecrow
    Scarecrow New Member
    Zack
    06 Tundra SR5 4.7 v8 4x4
    I would recommend changing it and the pump. Best to hit it before you throw a rod.
  12. Aug 21, 2016 at 8:41 PM
    ratio411
    ratio411 2006 2wd DC
    Dave
    Pensacola, Florida
    White 2006 DC 2wd
    Leer cap
    How could a timing belt cause you to "throw a rod"?
  13. Aug 21, 2016 at 8:50 PM
    Mike Tread lightly.
    south carolina
    2uzfe is a interference engine.
    Belt breaks at high rpm things break fast... Plus the 2uz is cast rods not forged so the rods are weak...
    jberry813 and Scarecrow like this.
