2006 SR5 Extra Cab
Discussion in '1st Gen Tundras (2000-2006)' started by TMFSHHD, May 15, 2018.
  1. May 15, 2018 at 3:01 PM
    TMFSHHD
    TMFSHHD [OP] New Member
    Kevin
    Trying to put the body ECU into programming mode to add keyless remotes. I insert and remove the key, cycle the key to lock/unlock 5 times, close and open the door. Once the door is opened the first cycle of "lock" the door locks but will not unlock or lock anymore "actuating", you can hear solenoids cycling but the door lock remains locked, I put the key into the ignition and turn on then right back off not starting, the locks do not cycle signifying that the ECU is in programming mode. I took it to a local non dealer Toyota shop, left him baffled. Any advice???
  2. May 15, 2018 at 3:22 PM
    Welcome from CO. A 1st gen owner should chime in soon!
