2006 sr5 4wd fluids
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, May 5, 2021.
  1. May 5, 2021 at 7:31 PM
    fighthedude
    fighthedude [OP] New Member
    Stopped by local pepboys in California today to find out they are changing to advanced Auto. Subsequently everything left over is 50% off. Not a huge inventory left but fluids they did have. There system said I should use 90wt fluid in rear differential. Can anyone confirm this or tell me what I should use? Or better yet tell me every fluid and I will pick up tomorrow. The differential is an LSD.
    PS. Asked the manager and he said every store in CA is going to advanced so check your local spot to see if having a sale. Cheers
  2. May 6, 2021 at 3:48 AM
    Professional Hand Model
    Hand Protectors
  3. May 6, 2021 at 6:34 AM
    irhunter
    irhunter New Member
    '03 Tundra V8, AT, 4x4, extra cab
    What does your owner's manual specify?
    I mean, you can trust the PepBoys computer, or posts by various unknown-to-you posters, or you can trust Toyota.
    Your choice.
    Roy
  4. May 6, 2021 at 6:39 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    I’d be sure to trust random internet posters and an auto parts shop over the actual vehicle manufacturer...lol....like when I took my wife’s ‘07 Odyssey for an oil change (was moving, no place to do it myself) and they recommended 0w30, to which I said nope....look at the oil fill cap....and make it high mileage....
  5. May 6, 2021 at 7:44 AM
    fighthedude
  6. May 6, 2021 at 7:56 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Besides differential, grab any Mobil 1 ATF fluid you can find. That stuff is over $10/quart.
    I usually wait for a 30% off at Pep Boys before I grab any.
  7. May 6, 2021 at 7:58 AM
    smokey0810
    Stranger danger....
  8. May 6, 2021 at 8:44 AM
    fighthedude
    A191E41B-7F74-4F37-B624-1048AF1657F2.jpg 49345591-5F27-4A98-B21A-5FAC028ACCA5.jpg ECD37299-8E07-407D-97DE-2D5631C0D05D.jpg E26DFC28-CFDB-4399-9F39-ACEA36DA1EAF.jpg
    The way I read it is. 90wt rear differential. Does it matter if it is dino or synthetic. I assume I also want to purchase one with limited slip additives.
  9. May 6, 2021 at 9:55 AM
    Jack McCarthy
    Bill
    North of Boston
    Interesting. I wasn’t aware Toyota switched over to the WS fluid for the first gens. Thankfully my 02 Tundra only requires Dexron 3 or equivalent.
  10. May 6, 2021 at 10:20 AM
    irhunter
    irhunter New Member
    Yes, interesting. The '03 calls for T-IV. It just keeps getting more expensive.
  11. May 6, 2021 at 2:09 PM
    Hand Protectors
    I’ve trusted two Goofy Service Shops over the years. One a Stealer and another a Local. Both have done shtuff wrong wrong wrong (see my build page for their Rear Axle Debacle). Autozoned will sell you ‘whatever’ the computer says which isn’t always right.
    Somethings like only using Dyno Lucas in the rear diff is trial and error I learned here. Call your Stealer (I did) and ask what they put in the Rear Diff? Mine says they use 75w-90 (wrong wrong wrong!) and they are a Toy Stealer!
    smokey0810 likes this.
  12. May 6, 2021 at 2:56 PM
    irhunter
    irhunter New Member
    I would say, "Exactly right." Autozone, independent mechanics, dealers, and so forth...have all been wrong at one time or another.
    Trust the owner's manual and the FSM for your year and model...for the first word on all these issues. Starting there...if a fellow decides to vary from the suggested practice, so be it. But, I suggest, always make your decision knowing what the OM and FSM suggest.
    Roy
  13. May 6, 2021 at 4:22 PM
    fighthedude
    I bought Mobile 1motor oil for tundra and ram. Got 4 bottles of Royal Purple 75-90w oil. Everything I seem to read says this is fine to use. Not really 90wt gear oil. All seems to be 75-90, 80-90, 75-145. I can also use it in front diff and transfer case. Does this seem acceptable?
  14. May 6, 2021 at 4:35 PM
    Hand Protectors
    I still stand behind post #2, but its your truck and bought stuff already so go ahead and put it in. I’ve not used the RP for diffs but a few say it sucks for our diffs. Mobil 1 75w-90 Synthetic made my Rear LSD chatter a little. Works fine in Transfer and Front Diff.
    Lucas 80w-90 solved it. Cheaper, too.
  15. May 6, 2021 at 5:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You'll never make any friends with that attitude.
  16. May 6, 2021 at 9:25 PM
    smokey0810
    Hahahaha....
