2006 Sequoia misfire?
Discussion in '1st Gen Tundras (2000-2006)' started by EdBassMaster, Sep 20, 2023.
  1. Sep 22, 2023 at 10:19 PM
    EdBassMaster
    EdBassMaster [OP] New Member
    Hey do you think oil in sparkplugs tubes from after replacing the valve cover gaskets could be part of the problem?
  2. Sep 23, 2023 at 6:12 AM
    Did you check to see how tight the plugs were? Loose plugs is a problem. Too much oil in the combustion chamber is a problem.
  3. Sep 23, 2023 at 9:01 AM
    EdBassMaster
    I'll go check the plugs. thanks
