2006 Pre-pressed rear axle assembly question.
Discussion in '1st Gen Tundras (2000-2006)' started by Redoak, Nov 28, 2024.
  1. May 24, 2025 at 6:05 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    OE all the way. This job is too much work to waste on cheap parts.
    ToyotaDude and shifty` like this.
  2. May 24, 2025 at 6:39 AM
    The factory lasted you how long?
    Aftermarket parts typically have a maximum lifespan of 3-5 years, if you’re lucky. We’ve had people spin out aftermarket bearings in less than a year, for example. This is not a job you want to do twice, my friend.
    OEM costs more. Mostly because it’s intended as along-life replacement comparable or identical to what was installed at the factory. Buy once, cry once. Or buy aftermarket parts and replace 3x-4x in the same time period OEM gets replaced once, while spending more in the long run.
    The choice seems obvious to me. Even with the dollar being tighter than ever, time is money all the same.
    ToyotaDude likes this.
  3. May 24, 2025 at 3:03 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    For me would only use Toyota seals, and true Nachi bearings. During 25% off sales from Toyota can get everything very economically when able to plan ahead but if in a pinch found can source the bearing at Napa and Advance.
    https://www.tundras.com/threads/weird-rear-wheel-bearing-circlip-issue.144332/#post-3631838
    Cost Comparison in writeup. All Toyota was only $105/side for everything needed and free shipping (bearing, retainers, snapring, dust seal, oring, and oil seal).
    shifty` likes this.
  4. May 24, 2025 at 4:06 PM
    Moneyhoney73
    Moneyhoney73 New Member
    2006 Toyota tundra
    The parts came from NAPA these parts are not too reliable………
    Thanks for your reply, for I am a newbie ……..
  5. May 24, 2025 at 5:42 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    This weekend several online Toyota dealers have parts sales.
