2006 Headlight replacement and radio not coming on - help
Discussion in '1st Gen Tundras (2000-2006)' started by NEXT, Sep 23, 2020.
  1. Sep 23, 2020 at 8:50 AM
    NEXT
    NEXT [OP] New Member
    2006 Tundra crew cab SR%
    None
  2. Sep 23, 2020 at 1:42 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Radio fuse?
  3. Sep 23, 2020 at 2:05 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    well, I suggested replacing the timing belt, but we're looking at headlights, ok. I've always felt that the stock units, polished and cleaned up look the best. You could Buy a set of Morimoto LEDs and have excellent headlights.
    And, yes, check the radio fuse.
  4. Sep 23, 2020 at 2:09 PM
    Skyride56
    Skyride56 New Member
    Joe
    Franklin, TN
    2005 Black Tundra Limited DC
    Leveled w/ Bilsteins 5100, 285 70R17 Nitto Ridge Grapplers, 17x9 +01 Fuel Vapor wheels
    I purchased the Autosavers set, the outer lens cover, housing, and mounting tabs are made of thin plastic compared to OEM. When installing, one of the lower tabs broke off when tightening down because the lower bracket was maybe 1/4” lower (slightly bent). I removed the set and just refinished my OEM headlights and threw them back in and sent back the new set. They would be a ok replacement until you’re hit with a small/medium rock. Just hang on to your OEM unless they’re unuseable.
    N84434 likes this.
  5. Sep 23, 2020 at 2:09 PM
    NEXT
    None
    Timing belt, water pump, and all fluids(oil, brake, transmission, rear,) getting done Friday.
  6. Sep 23, 2020 at 2:15 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Good choice
    good choice!
  7. Sep 23, 2020 at 8:35 PM
    toyoboyo
    toyoboyo New Member
    The ebay headlights are decent. Not OEM fitment but they work.. Adjustment is iffy. Still better than fogged up OEM lights.
  8. Sep 23, 2020 at 8:58 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    I am going to try polishing-restoring my oems soon. I saw this on youtube and it looks fairly easy to do.
    https://youtu.be/vwHScSPj_Yw
    with...
    https://www.amazon.com/dp/B001AIZ5HY/ref=cm_sw_r_cp_apa_fab_EAbBFb5993XJS
    there are some really good led headlight setups with projectors you can do for about the same price as that Amazon junk. also there are a couple of good threads on this site that will help.
    Order a new head unit while you are doing the radio fuse.
  9. Sep 23, 2020 at 10:48 PM
    artsr2002
    'Yonder
    If your OEM lights can be polished that is the best way to go. The aftermarket lights are all pretty chitty quality wise.
    If you plan on retrofitting, the aftermarket are easier to open since most use butyl but, again, if you are able to polish your OEM lenses, I would do that.
    I polished mine a while back before going to a retrofit.
    N84434 likes this.
  10. Sep 23, 2020 at 11:06 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    I found using 'Cerama Bryte' works very well at polishing headlights.
    The stuff is expensive and you only need a little. If you or someone you know has a ceramic (flat) cook top stove they will have a bottle of it to clean their stove.
    If not can buy a bottle, costs about 20 dollars and can do yours then go into business polishing headlights.
  11. Sep 24, 2020 at 1:18 AM
    artsr2002
    'Yonder
