2006 Double Cab Tundra
Discussion in '1st Gen Builds (2000-2006)' started by 2006Tundra, May 27, 2020.
  1. Feb 4, 2022 at 11:41 AM
    #181
    2006Tundra
    2006Tundra [OP] Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Thank you! Lots of time and money to keep her around for a while.
  2. Mar 2, 2022 at 5:48 PM
    #182
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Those headlights and lightbar behind the grill looks so good, nice truck!
    Also your tacoma is a beast as well!
  3. Mar 2, 2022 at 6:56 PM
    #183
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I just started checking out this build with more attention. I'm told the truetrac is a go to, I would have got it but decided i needed switchable. I hope you are loving it. After looking a lot, these KCs seem like the call for me. Great work as far as I've read!
  4. Mar 3, 2022 at 6:04 AM
    #184
    2006Tundra
    Lou
    Long Beach, CA
    Thanks and Thanks! The Tacoma is my money pit. It quickly snowballed into what you see today. I'm still saving money for the rear suspension.
    Thank you. The TrueTrac wasn't necessary for what I'm doing with the truck, which is the daily/family/tow truck but since I was in there, I figured why not. It did help when I went to the snow last year. Worked like it suppose to and way better than the stock LSD.
    My next money pit idea is installing a ARB compressor. Stay tuned. I already installed the compressor in the engine bay, just need to wire it up.
    805Tundra[QUOTED] likes this.
  5. Mar 3, 2022 at 6:18 AM
    #185
    alb1k
    Left Coast
    It's good
    Sweet, let's see that. I have a twin compressor that is waiting for some love. I need to check if it will fit with seat jackers on the passenger side or goes over the PS pump. Probably the next weekend project.
  6. Mar 3, 2022 at 6:24 AM
    #186
    2006Tundra
    Lou
    Long Beach, CA
    I found a bracket for the engine bay :)
    https://www.kamdesignstudios.com/compressor-mount-v2
  7. Mar 3, 2022 at 6:26 AM
    #187
    alb1k
    Left Coast
    It's good
  8. Mar 3, 2022 at 6:28 AM
    #188
    2006Tundra
    Lou
    Long Beach, CA
    It holds up pretty well. It doesn't bounce up and down but there is slight side to side movement. I'm going to make a bracket to help with that. For the most part, its nice. I'll take a picture when I can.
    alb1k and Casper421 like this.
  9. Mar 6, 2022 at 7:21 PM
    #189
    2006Tundra
    Lou
    Long Beach, CA
    I haven't posted the latest updates but I will soon. So far I've installed Firestone air bags for the rear suspension, a Yakima rack with Jet stream bars on the Snugtop Shell and onboard ARB air compressor. Here's a little teaser. Still need to find the time to wire her up. The mount is from https://www.kamdesignstudios.com/compressor-mount-v2
    Kimosabe, 805Tundra, alb1k and 2 others like this.
  10. Mar 6, 2022 at 7:49 PM
    #190
    alb1k
    Left Coast
    It's good
    That looks solid. When you say side to side, are you talking about forward, back? I'm sure I could flex the inboard/engine side fore and aft with man hands. But it looks tight in pics.
  11. Mar 6, 2022 at 7:59 PM
    #191
    2006Tundra
    Lou
    Long Beach, CA
    Yeah, very slight forward and back movement. I want to make a bracket that attaches to the firewall and the mount to help with it. Over all, it’s very solid. I have notice that the compressor gets very hot in the engine bay after a drive. I hope it doesn’t mess up the compressor over time.
  12. Mar 6, 2022 at 8:01 PM
    #192
    alb1k
    Left Coast
    It's good
    BTW, wiring is stupid on these things unless you are using front and rear ARB lockers. I figured out how to hide and clean it up with my install, but my install is unusual. @daveeasa can probably tell you how to bypass a bunch of stuff, unless you need it.
  13. Mar 6, 2022 at 8:06 PM
    #193
    alb1k
    Left Coast
    It's good
    I've noticed with any weight and cantilever, there is flex in the bay because the anchor points are sheet metal for the most part. A tie in to the firewall will take care of any concerns, IMO. Everyone mounts in the engine bay. Where you are heat is not a problem. Even with lockers and driving, the compressor is not on all the time. No problem.
  14. Mar 6, 2022 at 8:12 PM
    #194
    Casper421
    In the woods
    06 DC
    That’s what I did with some riv nuts in the fender wall. It’s solid now, no movement!
    2006Tundra[QUOTED][OP] and alb1k like this.
  15. Mar 6, 2022 at 8:36 PM
    #195
    daveeasa
    David
    I got my bracket recently too, but of course haven't even begin to attempt.
    I do have a bunch of the connectors, buuut, if I'm dumping the switch in the bracket (I think his info says you can snap it right in?) then maybe I just go with their lame freebie harness after all? On the Tacoma I'm going bedside and switchpros so definitely won't use it there. Don't really love inline fuses though, I kinda prefer the MBRF or blue sea circuit breaker, but I can see how maybe they want each side fused independently.
  16. Mar 6, 2022 at 9:02 PM
    #196
    alb1k
    Left Coast
    It's good
    Well, I might have done a big no-no, but I have a BS breaker and I needed a fat run to the battery. So out the firewall on passenger side, BS breaker (100a), #2 cable to battery and the inline fuses at the battery. I'm at the battery with #2, haven't got past that tonight.
  17. Mar 6, 2022 at 9:06 PM
    #197
    daveeasa
    David
    Yeah, I really like the MRBF at the battery terminal, clean and no extra stuff, you really don't expect that one to go and you can fuse it high if you're fusing downstream, it's just there to protect the cable from hitting the chassis.
    alb1k likes this.
  18. Mar 6, 2022 at 9:14 PM
    #198
    alb1k
    Left Coast
    It's good
    I like it, I have no idea what you are talking about :rofl: But, I'll take some pics and you can tell me if it's a no go. I think it's fine, because I'm using the 40 amp inline fuses at the battery, the #2 cable is pretty much moving the battery to the firewall I think. I put in the breaker because I haven't another good on hand method of going from 2- #8 to 1- #2, and it gives me a cut off. Now, I have to take pictures in the dark :)
  19. Mar 6, 2022 at 9:16 PM
    #199
    daveeasa
    David
    Yeah, totally, circuit breaker is great to change gauge w a lug.
    MRBF just goes on the terminal and fuses it as close as you can possibly get. Here's a double, they have singles and maybe a triple too?
  20. Mar 6, 2022 at 9:20 PM
    #200
    alb1k
    Left Coast
    It's good
    And now it all makes sense, thank you, David.
  21. Apr 11, 2022 at 8:50 AM
    #201
    2006Tundra
    Lou
    Long Beach, CA
    I got bored with my stock exhaust so my buddy and owner of ERD Offroad is doing a custom stainless steel cat-back exhaust. We're doing an x-pipe with two Borla ProXS mufflers dumped behind the axle. Since the truck is in the shop, he's also building me a set of new leaf spring shackles with poly bushings for my new hangers from BBM Racing.
    New hangers from BBM Racing.
    Screenshot 2022-04-11 at 8.38.46 AM.jpg IMG_2311.jpg IMG_2310.jpg IMG_2309.jpg IMG_2308.jpg
  22. Apr 12, 2022 at 5:23 AM
    #202
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Soooooo sick!!
  23. Apr 12, 2022 at 7:51 AM
    #203
    2006Tundra
    Lou
    Long Beach, CA
    Once I get the truck back, I'll get a video of how it sounds.
    1stgentundradriver likes this.
  24. Apr 12, 2022 at 5:36 PM
    #204
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Thanks! About how much does an exhaust cost in your area? Wanting to mod mine as well.
    2006Tundra[OP] likes this.
  25. Apr 12, 2022 at 6:27 PM
    #205
    2006Tundra
    Lou
    Long Beach, CA
    The Borla mufflers cost be $224 for two on Jegs and another $700 for the material and labor.
    In coming pics that I just received.
  26. Apr 12, 2022 at 6:27 PM
    #206
    2006Tundra
    Lou
    Long Beach, CA
    Update on the exhaust. Still need supports and down pipes.
  27. Apr 12, 2022 at 6:29 PM
    #207
    805Tundra
    Ben
    Central Coast
    WOW!
    G_unit3000 likes this.
  28. Apr 12, 2022 at 6:30 PM
    #208
    2006Tundra
    Lou
    Long Beach, CA
  29. Apr 12, 2022 at 6:32 PM
    #209
    805Tundra
    Ben
    Central Coast
    Can’t wait hear it! You going to record the sound?
  30. Apr 12, 2022 at 6:36 PM
    #210
    2006Tundra
    Lou
    Long Beach, CA
    Sure am. I should've recorded the stock set up with the magna flow.
    805Tundra likes this.
