2006 4.7 cranks but no spark
Discussion in '1st Gen Tundras (2000-2006)' started by shaw0531, Jun 11, 2016.
  1. Jun 17, 2016 at 3:46 AM
    #61
    shaw0531
    shaw0531 [OP] New Member
    Jake
    2006 Spectra Blue Mica Tundra SR5 2WD DC
    Truck won't start this morning. Ive sprayed cleaner twice and she just cranks all day long. Any ideas where to go from here?
  2. Jun 17, 2016 at 6:10 AM
    #62
    Mike Tread lightly.
    south carolina
    Any codes in the ecm?
  3. Jun 17, 2016 at 6:19 AM
    #63
    shaw0531
    Jake
    Yes but my guy that has a code reader is out of town. My ultra gauge will be here soon but waiting on mail
  4. Jun 17, 2016 at 6:30 AM
    #64
    shaw0531
    Jake
    Thanks
    Yeah me too. I love the truck but ive only owned it almost 4 months and had to put almost $2000 into it in repairs. If I keep having to put money into it I'm going to end up getting something different cause I can't afford break downs every few weeks
  5. Jun 17, 2016 at 6:53 AM
    #65
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Where are you located? I've got a pretty good code reader. Also, I think I mentioned this before but I've got access to all the Chilton Repair manuals so let me know if you need anything.
  6. Jun 17, 2016 at 6:55 AM
    #66
    shaw0531
    Jake
    I'm in South Central Kansas. where can you pick up a Chilton manual? Any auto store?
  7. Jun 17, 2016 at 6:56 AM
    #67
    Nor7
    Any auto store should have a Chilton or something similar. I meant to say I have access to the complete Chilton Online Library.
  8. Jun 17, 2016 at 7:07 AM
    #68
    Nor7
    Ok, I hope this helps, I pulled everything I could find for the starting and ignition system that you could inspect.
    T-Rex266 likes this.
  9. Jun 17, 2016 at 7:10 AM
    #69
    Nor7
    Missed one, don't know if this helps since it sounds like you're starter is fine but here's the inspection procedure for the actual starter.
  10. Jun 17, 2016 at 7:19 AM
    #70
    Nor7
    Check this one out too. Says to inspect your timing belt for a jumped tooth. Might not be it but worth a look.
  11. Jun 17, 2016 at 7:21 AM
    #71
    Nor7
    If you can get me the exact code or if you remember it from earlier I can get better information.
  12. Jun 17, 2016 at 7:23 AM
    #72
    Nor7
    If all else fails, maybe try to splice the wires directly, sounds like it might just be the connector that's bad or shorted out.
  13. Jun 17, 2016 at 8:21 AM
    #73
    shaw0531
    Jake
    I'll let you guys know when I get off of work what code I get and such. How hard is it to replace the connector from the wiring harness that plugs into the sensor? I'm thinking it's something with that because cleaner was helping it before
  14. Jun 17, 2016 at 8:37 AM
    #74
    Nor7
    The new sensor should come with a harness. If you're referring to the truck side, I'd say order a new harness as well and it should come with pigtails and you could use some splice connectors.
  15. Jun 17, 2016 at 8:38 AM
    #75
    Mike Tread lightly.
    south carolina
    Im willing to bet that connector is bad on the ecm side not the sensors side.. Make sure the pins are secure in the connection..
    we will get it fixed.
    For that toyota doesnt sell the connector itself. IF you have access to a junk yard that has the connector you can cut the pig tail.
    For a solid connection solider the connections with heat shrink tubing.
    NewImprovedRon and Nor7 like this.
  16. Jun 17, 2016 at 10:43 AM
    #76
    shaw0531
    Jake
    Yeah I mean on the truck side
    They are secure, ive made sure each time I reconnect. Is there a way to replace that whole connector on the truck side without getting into a big electrical mess?
  17. Jun 17, 2016 at 11:37 AM
    #77
    Mike Tread lightly.
    south carolina
    Damn you really need a lab scope to see if your getting pick up past the connection in question.
    If you can find the connector you would be lucky..
    One thing you can to is make jumpers on all three wires on the sensor side and then use a jumper on the ecm side of the connector. That way you bypass the connection to make sure..
    When doing the test leave the connection disconnect.
  18. Jun 17, 2016 at 5:02 PM
    #78
    shaw0531
    Jake
    Could you give me one for the crankshaft position sensor? I can see what it looks like but don't know where it's located
  19. Jun 17, 2016 at 5:07 PM
    #79
    Mike Tread lightly.
    south carolina
    drivers side right behind the crank pulley..
  20. Jun 17, 2016 at 6:38 PM
    #80
    shaw0531
    Jake
    I picked up a new crank sensor for it as the code that came across now was crankshaft sensor. The one before was camshaft sensor circuit a
    We will see what it does
  21. Jun 17, 2016 at 7:06 PM
    #81
    Nor7
    Here you go. Crankshaft Position Sensor
  22. Jun 17, 2016 at 7:08 PM
    #82
    Nor7
    Camshaft Position Sensor
  23. Jun 17, 2016 at 7:09 PM
    #83
    Nor7
    The Camshaft sensor and the crankshaft sensor are different, not sure which one exactly you're looking for. Both are above. And I can get you the removal and installation procedures if you'd like them.
  24. Jun 17, 2016 at 7:11 PM
    #84
    Mike Tread lightly.
    south carolina
    This truck is confused on what sensor is bad...
  25. Jun 17, 2016 at 8:54 PM
    #85
    shaw0531
    Jake
    Replaced the sensor and still won't start and still getting code P0335. I've ran out of things to clean, and retry and check for these two sensors. I may have to have it towed to the shop and let them take care of it and cut my losses. Ive already spent a week, over $200 in sensors, and lots of cuss words and half a day off work trying to get this thing to start
  26. Jun 17, 2016 at 8:59 PM
    #86
    Mike Tread lightly.
    south carolina
    Does your obd2 you have reader or does it do live data?
  27. Jun 17, 2016 at 9:01 PM
    #87
    shaw0531
    Jake
    Right now I'm using the ultra gauge. The reader I usually use, the guy is out of town for the week
  28. Jun 17, 2016 at 9:12 PM
    #88
    Mike Tread lightly.
    south carolina
    Do this on the ultra,pause where it has rpms on the screen. Start it and see if it reads any rpms.. only way to test without a labscope off the top of my head here.
    You said the timing belt was done not too long ago right?
  29. Jun 17, 2016 at 9:52 PM
    #89
    Nor7
    Here's what I could find out about that code.
  30. Jun 17, 2016 at 9:55 PM
    #90
    Nor7
    Read that carefully and next time you try to start, check batt voltage and starting RPM etc. But it might come down to bum wires. I wish I could help more. Let me know if there's anything else I can help with, I hate having a member give up and go to the shop. PDF says most likely its a short or open circuit. Can you trace the wires all the way back?
