2005 tundra transmission problem
Discussion in '1st Gen Tundras (2000-2006)' started by Rustydog, Jan 7, 2019.
  1. Jan 7, 2019 at 7:36 PM
    Rustydog
    Rustydog [OP] New Member
    Charlie
    Limited 4x4
    None
    I have a 2005 tundra four-wheel-drive and my transmission shifts after I’ve come to a complete stop has anybody else had problems with this and if you did what did you do to fix it thanks
  2. Jan 7, 2019 at 8:11 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Does it feel like a bump? When was the last time you greased zerks and how old is the rear diff fluid?
  3. Jan 7, 2019 at 8:21 PM
    Rustydog
    Charlie
    Limited 4x4
    None
    I had this problem before they replaced the solenoid and took care of it and now it’s coming back
  4. Jan 7, 2019 at 8:24 PM
    Rustydog
    Charlie
    Limited 4x4
    None
    It does feel like a bug and I will check the differential fluid state thank youThanks
  5. Jan 7, 2019 at 8:41 PM
    Rustydog
    Charlie
    Limited 4x4
    None
    I mean it does feel like a bump
  6. Jan 7, 2019 at 8:44 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Have you ever done the trans fluid swap or change? Look at the zerks also.
  7. Jan 7, 2019 at 8:55 PM
    Rustydog
    Charlie
    Limited 4x4
    None
    I have done the transmission drain and Fill I will check zerks
    I am in Tempe Arizona do you know a good transmission shop in the area
    thanks
  8. Jan 8, 2019 at 4:28 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    To me, that does not seem like a transmission problem. I would check the zerks first. When they get low, they can produce a bump.
  9. Jan 8, 2019 at 8:39 PM
    Rustydog
    Charlie
    Limited 4x4
    None
    Ok thank you
  10. Mar 28, 2019 at 10:19 PM
    SilverCedar
    SilverCedar New Member
    2006 Tundra SR5
    What zerks are you referring to? My truck makes a little extr clunk sometimes after coming to a stop. I thought it was my pads holding on a little extra or something, but after reading this I wonder if I’m in need of some lubing.
    What’s a standard greasing entail? I just bought a Chilton guide but haven’t figured that out yet.
  11. Mar 29, 2019 at 7:50 AM
    speedtre
    speedtre New Member
    Inland Northwest
    It's essentially the slack being taken up in the driveline which is made more noticeable by the fact we have 2 piece drive shafts. I've had a 2002, 2005 and 2006 Tundra...both access cab and DC...they all did it. Some people report temporary fixes of lubing the driveline where there are zerks fittings...but it's really nothing to worry about other than being annoying.
    revtune likes this.
  12. Mar 29, 2019 at 11:31 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Zerks are the grease fittings that your grease gun snap onto. I'm having the same issue as you. Try greasing all the U Joints first and see if that eliminates the problem. If not more troubleshooting may be needed.
  13. Mar 29, 2019 at 11:36 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    That, and check for play in the driveshaft itself. Check your carrier bearing too while your under there.
  14. Apr 8, 2019 at 1:39 PM
    JQ3
    JQ3 2005 XSP rwd
    I had the same “bump” in my truck. I had my transmission fluid changed today and I didn’t notice it on the drive home. I’m wondering if it was low for some reason. I bought the truck used back in October with 94K, so I have no idea when it was replaced last.
