2005 Tundra Fuel Issues
Discussion in 'New Member Introductions' started by Marco5<4x4, Jul 30, 2022.
  1. Jul 30, 2022 at 5:30 PM
    Marco5<4x4
    Marco5<4x4 [OP] New Member
    05 Tundra 4WD TRD
    2005 4.7 Tundra. At 340,000 the timing belt broke { I changed it @ 255000} smashed 2 valves and killed the head. Replaced the heads and put everything back as before. Has run great for 2500 miles and not sure what has gone wrong. The engine stalls after starting every time. If I turn on the switch and wait approx. 5 seconds to start, it doesn't stall. Upon normal acceleration the engine will stumble as if it is running out of gas. Let off and let it catch up and it will continue on. Installed new fuel pump and nothing changed. If you accelerate slowly it will run fine. Not sure what is going on ???
  2. Jul 30, 2022 at 9:48 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    First off, you would have a better chance of a knowledgeable response if this information was posted in the “ask a Toyota Mechanic” portion of this forum. Lots of experts to help you out there. Next point of business: Welcome and Greetings from Minnesota.
    Tripleconpanna likes this.
  3. Aug 1, 2022 at 4:54 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I agree with the previous post. Sounds like something is impeding fuel flow.
