2005 Instrument cluster
Discussion in '1st Gen Tundras (2000-2006)' started by djerry05, Dec 18, 2024.
  1. Dec 18, 2024 at 11:32 AM
    djerry05
    djerry05 [OP] New Member
    Jerry
    2005 Tundra
    Will a 2004 instrument cluster fit a 2005? If not, can the bulbs in the 2005 be replaced with LEDs even though they are soldered?
  2. Dec 19, 2024 at 10:34 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yes and no.
    Not all FGT gauge clusters are interchangeable
    . You will need to verify that you are buying the correct part number to ensure that it communicate with the ECM.
    The part number can be found on the left side of the cluster. See pic for example.
    Here's some 2005 bulb info:
    Also, check these threads: Search Results for Query: instrument bulb | Toyota Tundra Forum
    FrenchToasty likes this.
  3. Dec 22, 2024 at 7:47 PM
    djerry05
    Jerry
    2005 Tundra
    Thanks, Black Mamba. Very good information. Even better information in John 3:30.
    The Black Mamba likes this.
  4. Dec 23, 2024 at 3:47 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Him > , Me <
  5. Dec 23, 2024 at 12:14 PM
    shifty` We call it “riding the gravy train”
    tl;dr - 2000-2004 cluster is not really usable in 2005-2006. Not only are they different # speeds in the transmission, the way some gauges like speed are fed (for one example) diff’t. Only option to change colors and keep cluster intact is with a soldering iron, solder wick, and new surface mount LEDs, installed in correct orientation. Pinouts in the rear don’t match up between different drivetrains as well, at least in earlier years.
