2005 Access Cab on BaT - 20k miles
Discussion in '1st Gen Tundras (2000-2006)' started by Pnw_tom, Aug 29, 2021.
  1. Sep 24, 2021 at 5:23 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    I’m not sure if a have the premium sound system, most likely not, I have been wanting to install that stereo on mine. Just wondering if it would be a difficult install. Thank you.
  2. Sep 24, 2021 at 5:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Toyota sells the adapter harness and a microphone to make the Bluetooth work and steering wheel controls work. If you don’t mind wiring you can make the reverse camera work and have speed input into the radio for the factory nav too. I’ve been happy with mine. I actually went a bit further and setup front and rear any time camera module for a 3rd gen Tacoma
  3. Sep 24, 2021 at 5:44 PM
    Toyoda Tundra
    Do you know if the steering wheel controls are prewired or the whole steering wheel needs to be replaced to add the controls. Btw I just realized I came across your YouTube videos a while ago lol
  4. Sep 24, 2021 at 7:19 PM
    empty_lord
    05 rollover special
    My truck was wired to the spiral
    Cable, but I had to add three wires to the radio harness itself.
    Toyoda Tundra[QUOTED] likes this.
  5. Sep 24, 2021 at 9:48 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    #WhistlnDiesel
    tunyota likes this.
  6. Sep 25, 2021 at 5:58 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    That's just mean.
    Diablo169[QUOTED] likes this.
  7. Sep 25, 2021 at 7:05 AM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Yeah. 2022 is a third generation.
  8. Sep 25, 2021 at 5:48 PM
    shifty` Waving My Dick In The Wind
    Airbag and/or at least the airbag cover needs to be replaced to add controls to the wheel. Wheel is the same, generally, and multiple Toyota models including some Sienna and Camry used the same wheel, with varying colors.
    As for whether or not the truck is pre-wired to accept the steering wheel controls, that's the $20,000 question nobody has answered. Seems the answer for later years where it was a factory question is "yes" (like, '05/'06 all I've seen were pre-wired). For earlier years, it may not be the case, which means you may be adding a newer-year clockspring at least, and maybe some sub-harnesses or wiring fill-ins.
    I can seek out the big post I wrote up about wheels and wheel controls if you really want it.
