2004 tundra SR5 DC passenger power lock not working
Discussion in '1st Gen Tundras (2000-2006)' started by griffinbristow, Nov 20, 2020.
  1. Nov 20, 2020 at 8:08 AM
    griffinbristow
    griffinbristow [OP] 2004 tundra SR5
    Griffin
    Alabama
    2004 Toyota Tundra SR5 4x4
    3” leveling kit, 33” nitto ridgegrapplers, full audio restoration
    So I’ve had my truck for a little over a year now and ever since I got it the passenger door lock has never worked correctly. The door still locks but you have to either walk around and put the key into the door or reach over from the driver side to lock/unlock it. Even when you press the lock/unlock button on the driver door or passenger door it still will not lock. It always has to be manually locked. I was wondering if there was some simple fix to this issue. I’ve already checked all of the fuses and made sure they are all good so I know it’s not that. I was also wondering if there is a way to configure w key fob for this year of truck. Did it come with one? Is there a way to program a new one?
  2. Nov 20, 2020 at 6:20 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    Sounds like a bad door lock actuator to me I just replaced the drivers side one on mine. I bought the wrong one originally and forgot to return it could be yours for free 99 if it's the right part. 746-638 6 pin connection mine was a 4 pin.
  3. Nov 20, 2020 at 6:52 PM
    shifty` Waving My Dick In The Wind
  4. Nov 20, 2020 at 6:58 PM
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    2nd this...sounds like the door lock actuator. I replaced about 4 over the years in my 07 taco.
    There are a lot of YouTube videos on replacing them in Toyota’s.
    From my experience the door lock actuator costs about $200-$300 from Toyota if I remember correctly... but replacing the whole actuator is not needed.
    It’s the little DC motor inside the actuator that usually goes faulty and those run less than $10 bucks.
    If you try this just take your time and be very careful. Pretty much you will need to get the actuator out of the door then open up the actuator to swap out the little dc motor. I did this over the years on all four doors and never had any other issues with them.
    Below is an EXAMPLE of what the DC motors look like.
    2 Pack - 10mm ROUND SHAFT FC-280PC-22125 Central Door Lock Actuator Motor, ROUND SHAFT, Circle Spindle, Power Locking Repair Engine Replaces Mabuchi https://www.amazon.com/dp/B01H7PCW8I/ref=cm_sw_r_cp_api_fabc_n.hUFb6TMQ16Z
  5. Nov 21, 2020 at 8:59 AM
    griffinbristow
    Griffin
    Alabama
    Thank you, when I get back into town I’m gonna take a look and see which pin it is. Hopefully it’s the 746-638 6 pin
    GavinG83[QUOTED] likes this.
  6. Aug 2, 2024 at 5:42 AM
    KreamDC
    KreamDC New Member
    2006 Tundra DC Limited 4wd
    Can anyone confirm this is true for a 2006 DC? I did do this for a Tacoma but I wanted to confirm this can be done for 06 Tundra DC
