2004 Tundra Long Travel PreRunner Build
Discussion in '1st Gen Builds (2000-2006)' started by MRKSe7en, May 3, 2019.
  1. May 28, 2019 at 8:44 PM
    MRKSe7en
    MRKSe7en [OP] New Member
    2004 Toyota Tundra 4WD
    So I didn’t really drive the truck much stock, being that I purchased it then went into the build shortly after. So I can’t give that accurate of a comparison. However it drives like I remember it did stock. I was expecting a lot of power loss, but I don’t really feel it. Again, this is having drove it maybe 5 times prior to replacing the gears.
    SCRunner12[QUOTED] likes this.
  2. May 28, 2019 at 8:56 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Great build!! Lets see some video of the truck in action soon :bikewhoops::bikewhoops::bikewhoops::bikewhoops:
    MRKSe7en[OP] likes this.
  3. May 28, 2019 at 10:01 PM
    TheBeast The Beach
    very nice ! looks very capable
  4. May 31, 2019 at 3:26 PM
    Riley_Nutt
    Riley_Nutt New Member
    Riley
    2001 tundra TRD
    What size lift is on it?
  5. Jun 4, 2019 at 7:07 PM
    MRKSe7en
    1 1/2 inches on the rear plus whatever the tires add, and 2-3 inches on the front plus tire height.
  6. Jun 4, 2019 at 9:10 PM
    Riley_Nutt
    Riley
    2001 tundra TRD
    Does the long travel kit add a lift too or should I just get a lift because it’s too expensive for me to get a a LT kit
  7. Jun 4, 2019 at 9:15 PM
    Riley_Nutt
    Riley
    2001 tundra TRD
    What did you put on the front for the 2-3 inch and the rear for the 1-1/2
  8. Jun 5, 2019 at 11:04 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you go back to the first page he's got everything listed. The front would be the King coilovers and the rear is the custom leaf pack.
    This is an outstanding build. Keep it up @MRKSe7en
  9. Jun 5, 2019 at 12:06 PM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Your truck looks great!
  10. Jun 5, 2019 at 7:55 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    What are the length of the rear shocks? Maybe 12" x2.5"?
  11. Jun 5, 2019 at 11:12 PM
    MRKSe7en
    Exactly.
  12. Jun 6, 2019 at 2:59 AM
    KarmaKannon
    Utah
    Some junk
    Perfect, I was really hoping 12s would fit. Now I just need to try and make 3.0s fit in there without some crazy wheel spacers. I guess there is always inside the frame.
    Sweet truck by the way.
  13. Jun 6, 2019 at 3:48 AM
    KarmaKannon
    Utah
    Some junk
    Also... Do you happen to know if your front tire is pushed forward more than stock? I would imagine they move it 1-1.5", but I don't think I've seen it mentioned anywhere.
    Thanks
  14. Jun 6, 2019 at 9:01 AM
    MRKSe7en
    The 12’s don’t fit without modifications and rear wheel spacers. I have inch and a half wheel spacers in the rear and I’d say that’s the minimum, I want to replace them with 2 inch eventually.
    Pushed forward? Not sure. The kits itself increases the track width by 7 inches, 3.5in on each side.
    Sunnier and Alexstundra like this.
  15. Jun 6, 2019 at 10:11 AM
    KarmaKannon
    Utah
    Some junk
    I don't know if it does actually push the tire forward. It's just a fairly. Common thing to do on suspension to get more room against the firewall.
    I'm guessing you used the TC extended CV shafts? Did you just use oem cvs or do you know if they are aftermarket? Tc states their shafts only work with oem cvs, but I'd be willing to bet some of the aftermarket brands would work.
  16. Jun 6, 2019 at 11:58 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Thing looks like a Raptor with the glass. Looks good. Take some vids out in Nellis and post em up. My roots are in LA, but I've got branches in LV. Not sure if GKG means Go Kings Go or Go Knights Go. In any case, GKG.
  17. Jun 6, 2019 at 12:14 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have only seen one long travel tundra kit that pushed the wheels forward.
    https://btffabrication.com/products/99-03-2wd-tundra-longtravel
  18. Jun 14, 2019 at 3:28 AM
    KarmaKannon
    Utah
    Some junk
    Any more updates op? I'm using you and your truck to motivate me to build my front suspension.
  19. Jun 14, 2019 at 9:28 AM
    #49
    MRKSe7en
    Yes. I’ve been moving this last 2 weeks so I haven’t had much time but I took her out on some trails the other day and she handled great. I am having some issue with my tires rubbing my fiberwerx front fenders. So I trimmed a little off and still have to see if more adjustments are needed.
    Let me know if you have any questions.
    Here is some pics!
    7A2B939C-FC9F-4ACA-AE37-609DC08C7DFB.jpg A95B016C-4CE4-43C7-BD25-F51B3881344B.jpg 6205AB1F-4B65-47DE-8CB9-DADDDB85F260.jpg
  20. Jun 14, 2019 at 10:19 AM
    #50
    KarmaKannon
    Utah
    Some junk
    Very nice. I was actually worried my fenders would need to be trimmed and they are a little smaller than yours I believe. Thanks for the motivation. My wife finally conceded to letting me build the front suspension but her terms were " but it can't take as long as your last truck!". Haha
    I just started my lower arm fixture and now I'm figuring out how to convert the lower to a uniball. Should be fun. Oh and I may have some questions, thanks in advance.
  21. Jun 25, 2019 at 3:22 PM
    #51
    KarmaKannon
    Utah
    Some junk
    Hey MRKSe7en,
    Did you modify you intake at all after the fenders? I noticed my filter got killed after I did my fenders and removed the inner fender plastic. I had to route a tube up through the front bumper. I plan to do the intake through the cowl under the windshield eventually. Unless you have some other ideas I can steal haha.
  22. Jun 25, 2019 at 8:13 PM
    #52
    MRKSe7en
    No but I installed a cold air intake so I guess I didn’t experience that issue at all. I just got a cheap $50 cold air intake on eBay and then put a K&N air filter on it.
    #52
  23. Jun 26, 2019 at 7:04 PM
    #53
    KarmaKannon
    Utah
    Some junk
    How does the knn stand up to the dust? The oil type filter always concerned me but it could 100% be an unfounded concern.
    #53
  24. Jun 27, 2019 at 12:08 AM
    #54
    SRfiver
    SRfiver New Member
    Rick
    17 Tundra SR5 White
    ICI Magnum steps, BAK flip tonneau, looking for a lift and wheels
  25. Jun 28, 2019 at 7:07 AM
    #55
    Sunnier
    Sunny
    San Diego, CA
    I don't know if you got your answer yet about whether the wheels move forward-? They don't, but at alignment, I had 'em moved as far forward as possible, which stopped my tires from hitting the cab mount at full lock in reverse. I have basically the same front suspension on mine as this has. Yes, used the OEM shafts.
  26. Jun 28, 2019 at 7:18 AM
    #56
    KarmaKannon
    Utah
    Some junk
    That's good info thanks. Looks like I should try and push the tire forward .5-1" since I won't have any adjustment in the lowers.
    Sunnier[QUOTED] likes this.
  27. Jul 26, 2019 at 4:45 PM
    #57
    MRKSe7en
    Hey guys. Just an update since last time. I took her out for some fun and broke the rear shock mounts. Turns out the method used to mount them wasn’t the best. Here’s the damage:
    So after some more thought the guys at Nafarious Kustoms came up with a more reinforced mounting method and that issue shouldn’t happen again. It’s mounted to the frame with a steel tube reinforcing across the frame. Also rebuilt the shocks since the mount broke the hose. Check it out:
    Finally you can’t find anything online for these trucks anymore. So I had a custom bumper made for the rear and trimmed the fiberglass to match. Turned out amazing. So happy with it. The license plate folds down to expose the tow hitch.
    Next up: Exhaust Upgrades and custom center console.
  28. Jul 26, 2019 at 5:12 PM
    #58
    KarmaKannon
    Utah
    Some junk
    You might be my spirit animal . Looks like all great improvements to me. If be interested in seeing a picture of the rear bumper from straight behind the next time you are snapping shots. I used to think tube rear bumpers were the way to go, but I've seen some great looking desert trucks with aluminum or steel plate bumpers and it's a great look I think. Custom center console sounds fun. I'm an aluminum guy at heart and I've always dreamed of making a killer center console with mounts for a radio, equalizer, flashlight, drinks, and maybe other random stuff.
    What's the plan on the console?
    Sunnier, Darkness and MRKSe7en[OP] like this.
  29. Jul 26, 2019 at 8:55 PM
    #59
    MRKSe7en
    Here is the bumper from the rear.
    I never liked the look of tube rear bumpers, for some reason I feel like they look cheap unless they are the kind that you generally see on fancy prerunners, that hold the tires in the rear. I love a lot of C4 fabrication stuff and they inspired me to have a steel plate rear bumper built.
    As for the center console, I’m exploring ideas still. I don’t want to spend too much, the bumper was quite pricey, but I have a JL audio stealth box in my console right now and I lost all the storage space. So I’d like to build something that gives me a little storage and yes, hook up switches and CB to it. If I can get a fiberglass one made I prefer to do that. Otherwise I was considering making something out of MDF wood and carpet myself. I’ll keep you updated with what I decide.
  30. Oct 21, 2019 at 8:37 PM
    #60
    Riley_Nutt
    Riley
    2001 tundra TRD
    Are the fenders in the back full quarter panel or no
