2004 Tundra leaking rear end
Discussion in '1st Gen Tundras (2000-2006)' started by redskull, Oct 9, 2018.
  1. Oct 9, 2018 at 1:08 PM
    redskull
    redskull [OP] New Member
    My 2004 Tundra leaking rear end is leaking oil and now making grinding noise.
    Toyota replaced frame but not rusted rear end.
    They need to initiate a recall to finish the job on these trucks!!!!
  2. Oct 9, 2018 at 1:11 PM
    Casper421
    In the woods
    06 DC
    Is it leaking from the drain plug or from a rust hole? Any pics of the leak?
    01erionracing likes this.
  3. Oct 9, 2018 at 1:26 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    ^^^^^ This
    Casper421[QUOTED] likes this.
  4. Oct 9, 2018 at 2:07 PM
    Professional Hand Model
    Hand Protectors
  5. Oct 10, 2018 at 2:30 AM
    redskull
    From Bell housing, welded model.
    Whole rear end rusted up.
  6. Oct 10, 2018 at 7:41 AM
    Casper421
    In the woods
    06 DC
    Snap some pics.
  7. Oct 10, 2018 at 7:45 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Show us a pic or your rear. :anonymous:
    If it's real real rusty welding up the leak mightnot help. You might need to swap it out with a (less rusty ) Rear
  8. Oct 10, 2018 at 9:47 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
  9. Oct 10, 2018 at 10:00 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  10. Jun 28, 2019 at 4:18 AM
    Mytechguyri
    Mytechguyri New Member
    2004 Tundra 4x4 Access Cab step side
    Unfortunately that's not always the solution... I did that barnes 4wd cover (which its a very good quality piece by the way) , but mine is still leaking.... Seems when toyota did the frame recall, they covered my entire rear axle with POR (including the vent, which is what started my journey, differential gear lube under pressure and a small hole in the differential cover acts like a spray can...gear lube all over my camper i was towing).... But i digress.... The thing is... All that POR on the axle... The ENTIRE housing is pourous seeping gear oil through hundreds if not thousands of tiny pinholes almost the entire length of the axle tubes.... No other option but completely replacing the entire axle housing.
  11. May 2, 2021 at 4:21 AM
    Chris3504
    Chris3504 New Member
    2004 Tundra 4wd SR5 4.7l
    New exhaust headers (2019) New Magnaflow Catalytic Converters (Passed NJ emissions with these installed, factory Cats failed 2019) Borla Cat-Back dual exhaust (All stainless steel 2006) SkyJacker suspension lift (2006)
    Any luck finding a new rear axle? I live in NJ and decided to send the truck to a shop for some repairs.
    Shifter cable
    Fuel tank straps
    Rear brake lines
    Rear end is starting to leak and drum brakes havent worked in years. The shop states a that in order to replace backing plates for drums they need to drop axle. this would be a good time to weld a new cover being i have a slight leak. I havent had any luck locating a new rear axle VS the weld repair. any suggestions?
    Truck is a 2004, one owner, 160k miles... no body or frame rust but the rear end is pretty rusty along with a recent brake line failure, fuel tank strap breaking while driving, gear selector cable is very hard to shift, E-brake and rear drums havent worked in years, and lastly stearing rack is leaking bad. this is going to be a few thousand but truck seems sound otherwise.
  12. May 2, 2021 at 4:59 AM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    It’s completely worth it. On most other trucks 160k miles is 70% through its life, on our 1st gens it’s not even broken in yet. Engine and transmission will go through hell and back 840k more times.
    (Side note thank god I live in FL :p)
    RustyShackle323 likes this.
  13. May 2, 2021 at 5:18 AM
    Chris3504
    Thanks for the reply. I had this truck sold about 18 months ago for $8,900 and last minute I had a change of heart. Since then I’ve put about 500 miles on it and every time I fire it up it seems to have another issue.... thankfully not with the motor or trans. Keeping it alive is the plan and once I do then drive it more often.
    des2mtn likes this.
