2004 Toyota Tundra Frame Rust
Discussion in '1st Gen Tundras (2000-2006)' started by chazimm, Dec 18, 2018.
  1. Feb 6, 2021 at 6:11 AM
    #61
    Professional Hand Model
    Hand Protectors
  2. Feb 6, 2021 at 6:58 AM
    #62
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
  3. Feb 6, 2021 at 7:10 AM
    #63
    GingersMine
    GingersMine New Member
    Allan
    Ashby, Ma
    "Ginger" The Truck
    Stock: SR5 / TRD Off Road / TRD Dual Exhaust / 315/60/R18 BF Goodrich All Terrain T/A Custom Pin Stripe by Denise Day (D-Day Designs) Toytec / Eibach Lift Kit (2.5 Front / 1.5 Rear) / TRD Rear Sway Bar All Factory Side Badges have now been removed (Very Nice)
    Sounds like getting litigious is the way to go.
    I always hold out on that until the "nice" approach is to no avail.
    If you have any lawyer friends that can help with legal ease language you might get Toyota to wake-up.
    It's a shame that you may need to go this way, I personally avoid it if I can.
    I hand a replacement frame on my 06 Tacoma, it was in the middle of the campaign to fix these, and the known problem was inferior metal used for several years.
    Best of luck.
  4. Feb 6, 2021 at 7:43 AM
    #64
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Do not let them spray undercoating. Once they do that, truck is off their hands. They will say, it's now rust proofed and it's all good.
  5. Mar 30, 2021 at 2:13 PM
    #65
    DavidC96
    DavidC96 New Member
    David
    04 Tundra Double Cab 4WD
    Well update which really stinks for me...Toyota will not do anything for replacement and according to my local dealer parts dept there are no frames available nationwide and none scheduled to ship...sucks because I do really like the truck and cannot trust using it as a truck. So do I consider fabricating a frame since used ones are currently not available either since I missed out on the one I had found.
  6. Mar 30, 2021 at 2:30 PM
    #66
    Sometimes you gotta cut your losses. The alternative is to find a frame on a salvage vehicle from a rust free zone and undertake the painful process of destroying two Tundras and building one with the parts. Can't imagine the pain and suffering that would entail.
  7. Mar 30, 2021 at 2:32 PM
    #67
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    What's this?? A professional hand model should have manicured fingernails, not ones that look like they were cut with a $5 fingernail clipper and not filed. :monocle:
  8. Jun 20, 2025 at 12:23 PM
    #68
    mikhalljr12
    mikhalljr12 New Member
    2004 Tundra double cab sr5
    Just bought an 04 dc sr5 everything is great I looked at the farm and looked ok to me. Appeared to have a coating on it at some point but was mostly gone. Just had my mechanic check it out and there are several spots on both sides where it’s rotting. So now to find a frame any ideas?
  9. Jun 21, 2025 at 11:18 AM
    #69
    shifty` Inside his chest they found ten thousand pencils
    Start here my friend: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    You’re limited on frame options, to only the same cab type. That thread should explain it. Be prepared to spend some $$.
    Situations like this is EXACTLY why we created that thread, as a community. Sucks to see people get swindled like it sounds like you just did.
