2004 fuel pump wiring diagram
Discussion in '1st Gen Tundras (2000-2006)' started by Gino134, Sep 18, 2022.
  1. Sep 18, 2022 at 1:38 PM
    Gino134
    Gino134 [OP] New Member
    2004 Tundra
    2004 tundra. I need a fuel pump wiring diagram with color code. Thanks
  2. Sep 18, 2022 at 1:55 PM
    shifty` Countin' and breathin', disappearin' in the fade
    https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/#post-2058879
    If you aren't worried about being discrete when immobilizing, you could just pull the fuel pump relay in the fuse/relay box next to the battery.
    Rather than dicking around with the fuel pump itself, which is a PITA to work with, you could just as easily remove, wire into, otherwise utilized one of these three, which tie into the fuel circuit as you'll see in the EWD linked to just now, in that under-hood fuse/relay box.
