2004 DC headlights
Discussion in '1st Gen Tundras (2000-2006)' started by aricmagallanes7, May 2, 2021.
  1. May 2, 2021 at 4:30 PM
    aricmagallanes7
    aricmagallanes7 [OP] New Member
    I saw these headlights but says it won’t fit DC why is that? Or does anyone know black housing headlights for an 04 dc
  2. May 2, 2021 at 4:35 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. May 2, 2021 at 4:42 PM
    aricmagallanes7
    I can’t find any black housing ones for a dc
  4. May 2, 2021 at 4:43 PM
    FrenchToasty
    Mo
    Bone stock
    They do exist, I’m sure of it, the side marker is the big difference, I can’t remember what is different about the main headlight.
  5. May 2, 2021 at 4:46 PM
    aricmagallanes7
    You think I’ll be able to make a new bracket for them? Or try to find a way to make em work
  6. May 2, 2021 at 4:48 PM
    FrenchToasty
    Mo
    Bone stock
  7. May 2, 2021 at 4:49 PM
    FrenchToasty
    Mo
    Bone stock
  8. May 2, 2021 at 4:49 PM
    aricmagallanes7
  9. May 2, 2021 at 5:43 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    DC lights are physically bigger than AC lights, so they are not interchangeable.
    The only place I have sourced 2004+DC black lights are on eBay.
    SouthWestGA and des2mtn like this.
  10. May 2, 2021 at 5:44 PM
    aricmagallanes7
    You have a Link by chance? All the ones I’ve seen are for ac
  11. May 2, 2021 at 7:06 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Yep. They look just like the ones above. I haven't put them on though. I painted the reflector black, but the surround was black already, unless I'm mistaken. I've had a few sets over the last two years.
  12. May 2, 2021 at 7:18 PM
    aricmagallanes7
    How hard was it to do it yourself?
  13. May 2, 2021 at 7:23 PM
    KarmaKannon
    Utah
    Some junk
    The paint or the projectors?
    Paint is easy-ish if you like painting and using oven cleaner to remove the chrome stuff.
    Projectors are easy if you get the threaded style that keys into the old bulb area on the headlight housing.
    Etching the projector wasn't bad, but it requires a good stencil and a sand blaster with fine media.
    Taking the lense off the headlight housing is the part that's the hardest. Takes time and heat in the oven. Resealing them isn't too bad.
    It's all worth it if you like fiddling and you want better light that LEDs or halogens will give you in the factory housing.
  14. May 4, 2021 at 10:17 AM
    SouthPaw
    2000 Limited 4x4 AC
    Now that I’m looking, it seems they are all dried up. I’ve noticed the last few months prices on light assemblies have gone up and they are scarce. Chy-na must be having some importation issues I presume.
