2004 AC light blinking
Discussion in '1st Gen Tundras (2000-2006)' started by 71Cowboys, Mar 21, 2021.
  1. Mar 21, 2021 at 12:19 PM
    71Cowboys
    71Cowboys [OP] New Member
    Royce
    After depressing my AC button the compressor clutch kicks in for a second or two and the AC light starts blinking and the clutch releases. Hooked up some gauges on the freon lines shows about 100psi on the low side. Tried swapping relays for the AC/heater and checked the fuses are all ok. Anyone have any troubleshooting tips to further diagnose the Haynes manual is kinda vague on the AC issues
    Thanks
  2. Mar 21, 2021 at 1:03 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I had a problem on my 02 with A/C working intermittently, turned out after the mechanics replaced the t-belt/water pump they forgot to hook up the ground from the A/C compressor. Might be a ground :fingerscrossed:
  3. Mar 21, 2021 at 2:14 PM
    71Cowboys
    Royce
    Thanks, checked the ground is good. I am hoping for something simple and not a new compressor
  4. Mar 21, 2021 at 2:36 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Try the relay first.
  5. Mar 21, 2021 at 2:36 PM
    Roborob70
    Robert
    Oops never mind, failed to read the whole post.
