2002 Tundra skipping
Discussion in '1st Gen Tundras (2000-2006)' started by Smed4life!, Jan 16, 2019.
  1. Jan 16, 2019 at 3:32 PM
    Smed4life!
    Smed4life! [OP] New Member
    2002 tundra V8
    New frame 2018
    My 2002 Tundra has over 244,000 miles on it; I've replaced all spark plugs, all ignition coils, timing belt and water pump, cam sensor, but it runs fine, then all of a sudden it will start skipping like it's running on 7 cylinders. If I pull over and shut it off, wait 30 seconds, start it and it will run fine for a short time, then do it again. Sometimes I can run 10-15 miles before it does it again. It's driving me crazy, what is it? Help!
  2. Jan 16, 2019 at 3:44 PM
    Professional Hand Model
    Hand Protectors
    Try new fuel filter and new injectors and/or new fuel pump?
    Only time my truck felt like it was running on 7 cylinders was when a coil pack went bad. Looks like you’ve done all 8 with new. Now maybe its fuel related?
  3. Jan 16, 2019 at 5:54 PM
    Smed4life!
    2002 tundra V8
    New frame 2018
    If it was fuel filter, this would happen all the time. Don't think it's fuel related. Thanks tho.
  4. Jan 16, 2019 at 6:01 PM
    Blueknights75
    Ron
    Clayton, NC
    Did you replace all of the ignition coils at one time? Also if you did not use OEM coils that may be the problem as well. Had the same issue on my daughters 99 Maxima. Found out that if you replace a coil that you should replace them all and only use OEM coils. So after I replaced the other five coils it ran perfect even though I only showed a code for the one I replaced....
  5. Jan 16, 2019 at 8:46 PM
    Smed4life!
    2002 tundra V8
    New frame 2018
    Ron,
    Thanks for the information. What are OEM coils? Why would that matter?
  6. Jan 17, 2019 at 5:34 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    OEM-Original Equipment Manufacturer. Basically, you want to put in the same coils that came with the truck or something equivalent like the Denso's. If you with with a cheap Chinese option that may be your problem.
    I believe these are the best option.
    https://www.amazon.com/Denso-6731303-Ignition-Coil/dp/B002Y37M0W
  7. Jan 17, 2019 at 1:05 PM
    Smed4life!
    2002 tundra V8
    New frame 2018
    1/17/19
    Erik,
    If it were the ignition coils, it would happen all the time. So what do you think?
  8. Jan 17, 2019 at 1:26 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Brian I'm honestly not sure. Some things are best left diagnosed by actual mechanics. I'm just saying that from what I've read the inexpensive coils are not a good idea. Sorry I couldn't be more help.
    Blueknights75 and Sunnier like this.
  9. Jan 17, 2019 at 1:37 PM
    Hand Protectors
    Fuel system related? My guess again.
    244k miles is a long time on the fuel pump. When was last time fuel filter was replaced? Injectors probs have some gunk if filter is old.
  10. Jan 17, 2019 at 4:04 PM
    Blueknights75
    Ron
    Clayton, NC
    Honestly I have no idea. That’s what my mechanic told me. I was having the same sort of issues. This was on my daughters 99 Maxima. Went to autozone ran a diagnostic and found a faulty coil. So I replaced the coil with the cheapest coil Autozone had. Still had issues so took it to my trusted mechanic and he advised that whenever you replace a coil that you should replace them all and to use ONLY OEM. I trust this guy because he knew I was going to do the work myself before telling me this. So I purchased 6 new OEM coils and it solved the problem. It’s amazing how much better it runs. Good Luck and let us know what you find is the solution.
  11. Jan 17, 2019 at 6:42 PM
    Smed4life!
    2002 tundra V8
    New frame 2018
    1/17/19
    Thanks all.
