2002 Tundra RS 3000 remote alarm system
Discussion in '1st Gen Tundras (2000-2006)' started by bigcoaxum, Mar 20, 2019.
  1. Mar 20, 2019 at 3:21 PM
    bigcoaxum
    bigcoaxum [OP] New Member
    Mark
    2002 Tundra
    Can anyone tell me how to program the remote to this system? I've located the box and followed some basic instructions that i found online but they do not work. Please help
  2. Mar 21, 2019 at 6:36 AM
    speedtre
    speedtre New Member
    Inland Northwest
    When I bought a 1996 4runnner it had the RS3000 alarm/remote entry system but no key fobs, so I bought some off ebay for my year 4Runner and I followed these directions and it worked great.
    http://www.remotesremotes.com/v/vspfiles/photos/prog/toyota/rs3000.pdf
    About 3 months later both remotes stopped working. So I tried the same procedure...no luck. I then changed the batteries in both remotes, again, no luck. Very frustrating. I figured there was little chance that both remotes just broke simultaneously, so I took the RS3000 control unit out of my truck and carefully took it apart. It's very easy to do. The circuit board had some obvious corrosion on it....nothing terrible, but enough to stop a signal. I then used QC electronics cleaner to soak the areas of corrosion and very lightly scrubbed it off with a soft bristle toothbrush being careful the whole time. I put it back together and reprogrammed the remotes and voila, they have been working like champs for 6 months.
    TLDR version...check remote batteries first, if that doesn't fix it, then take out the RS3000 control unit, disassemble it carefully, carefully clean any corrosion using electronics cleaner and a soft bristle toothbrush, reassemble/reinstall and reprogram remotes.:thumbsup:
  3. Mar 21, 2019 at 6:40 AM
    Professional Hand Model
    Hand Protectors
    Any chance on someone posting a pic of the location of said circuit board?
  4. Mar 21, 2019 at 6:54 AM
    speedtre
    speedtre New Member
    Inland Northwest
    The RS3000 control unit for my 4runner was under the drivers seat and very easy to get to to take out. On a scale of 1-10 of mechanical difficulty, it's like a 1-2 on my 4runner.
    According to this thread, the location on a Tundra for the RS3000 is a much bigger PITA to get to...it has a few pics as well. There is a bit of confusion in the thread, so I suggest reading all of it...it's only 2 pages worth.
  5. Mar 27, 2019 at 7:39 PM
    bigcoaxum
    Mark
    2002 Tundra
    can anyone tell me where is the security light located? I can't seem to find it. I really would like to get my key fob working.
  6. Feb 26, 2021 at 11:13 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Apparently there isn't one for Tundra's equipped with the RS3000....or at least many FGT owners have reported being unable to find one.
  7. Feb 27, 2021 at 7:26 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    My 2003 Tundra has the RA3000 system (according to Toyota) and the security light is located to the right of the dash dimmer knob.
    RA3000, third from the bottom...
    Security light...
    I recently bought this fob and programmed it according to the directions.
    https://www.amazon.com/Keyless2Go-Remote-Replacement-Keyless-Installed/dp/B011RZ16Z4?pd_rd_w=DbFoB&pf_rd_p=c0dee9af-852c-4d19-9f11-5b16a874bf5e&pf_rd_r=BPKHPNKH38AZ2WGR4HMA&pd_rd_r=3b075052-95a0-48d7-8d72-1abd5d6776fa&pd_rd_wg=jDbow&pd_rd_i=B011RZ16Z4&psc=1&ref_=pd_bap_d_rp_1_i
    FWIW...
    speedtre likes this.
