2002 Tundra A/C issue
Discussion in '1st Gen Tundras (2000-2006)' started by ssqman, May 1, 2021.
  1. May 1, 2021 at 9:02 AM
    ssqman
    ssqman [OP] New Member
    2002 Tundra 4.7 V8
    Hi, new guy here. I'm having a problem with the A/C on my 2002 Tundra w/ 4.7 V8.
    When the A/C is turned on, the green light only works some of the time. When it is lit up the A/C blows cold. When it isn't lit up it blows warm. The fan/blower work all the time. Can you point me in the right direction for this?
  2. May 1, 2021 at 9:34 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Probably needs a charge,. How long does the compressor run? It's possible that the system is over-charged and it's shutting the compressor off when it hits the high-pressure limit switch.
    Or, it could need a slight charge to keep it off the low-pressure switch. Time to put some gauges on the system and see what it's doing..
    Welcome to the club!
    MS22 and Jack McCarthy like this.
  3. May 1, 2021 at 10:10 AM
    ssqman
    2002 Tundra 4.7 V8
    Thanks for the welcome. I'll pick up one of the recharge kits and see what it says.
    N84434 likes this.
  4. May 2, 2021 at 4:01 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Check your ground wire to see if its still in good shape. . A couple of months before I acquired my 02 the timing belt was changed but the mechanic forgot to hook up the ground wire that connects to the A/C pump. Welcome from Colorado!
